Aluminum Cam End Plugs
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Aluminum Cam End Plugs
03 May 2017 05:15
#761040
Scirocco wrote: In some rare cases...you have to do a little rework on the plug to fit in.
I speak of experience, i had to do it in my case.
The cam end plugs ( the Kawasaki rider here in Germany call them half moons ),normally fits so tight that you can use any kind of liquid gasket ( very thin layer of Hylomar blue ). They never come loose if i pull my valve cover to do a valve job .
Michael
Thanks for the heads-up. I expect some minuscule inletting if the fit is a little snug, and then the tops must be flush with the gasket surface...:pinch:
1982 KZ1100-A2/1170 sleeper 😀
  • havakaw
  • havakaw's Avatar
03 May 2017 09:40
#761066
I installed the same ones a few weeks ago. A word of advice. MAKE SURE you pre-fit them both with and without the valve cover on!!! I had 2 that fit perfectly, but the other 2 the holes were off size just a bit, and the bolts wouldn't go thru. I haven't fired it up yet to check for leaks. I used the copper goo cause that's all I had. Wish both of us luck!!!
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
The following user(s) said Thank You: GPz550D1, daveo
  • daveo
  • Premium Member
  • Premium Member
03 May 2017 22:15 - 03 May 2017 22:20
#761131
havakaw wrote: I installed the same ones a few weeks ago. A word of advice. MAKE SURE you pre-fit them both with and without the valve cover on!!! I had 2 that fit perfectly, but the other 2 the holes were off size just a bit, and the bolts wouldn't go thru. I haven't fired it up yet to check for leaks. I used the copper goo cause that's all I had. Wish both of us luck!!!
Same as these?
i.ebayimg.com/images/g/nEAAAOSwHQ9WaGyE/s-l1600.jpg
They arrived from Germany yesterday, and I took them to the man-cave for close examination and comparison to the stock ones we all love so-well.
These alum plugs are quite different in appearance and shape. Also, they are thinner which pulls the face back under the cover by approximately 1/32", so they will not flush out with the cover as I had hoped. :angry:
Havakaw, please post a couple pics of the installation on your engine.
Edge-edge comparison:
Misalignment of alum. plug with old ratty cam cover:
Correct alignment of Genuine Kawasaki, though they do migrate out-of-alignment after tightening and quick passage of time:
Last edit: 03 May 2017 22:20 by daveo.
  • Tyrell Corp
  • Tyrell Corp's Avatar
04 May 2017 07:51
#761148
I used Ducatibond on my cases, Hondabond and Yamahabond I guess very simlar, in Grey or black.
You could even be contoversial and try some 92104-1003 Kawibond.
  • havakaw
  • havakaw's Avatar
04 May 2017 09:13
#761164
Those pics show what I suspect was my problem. On one side of the haed, everything fit and lined up perfectly. On the other side, the bolt holes were off a bit, and I didn't notice untill I had the valve cover on and all bolted down. I ended up drilling the holes out in place and runing a tap thru just to make sure it was good. Sorry no pics from me. I got a flip phone. Maybe when I get the Delkevic on it I'll have my girl take the pics and upload them. Sent you PM about those clamps if you still have them.
'80 KZ 750 LTD-H
  • daveo
  • Premium Member
  • Premium Member
04 May 2017 10:03 - 04 May 2017 10:17
#761170
Thanks for the assessment. This may be a can of worms, which I'll regret opening.
If I do end up fitting them, I will photo-document for anyone interested.
Regarding the SS carb-manifold clamps...$25 shipped in USA :)
Last edit: 04 May 2017 10:17 by daveo.
  • daveo
  • Premium Member
  • Premium Member
08 May 2017 22:43
#761526
Two plugs fit without having to open the holes up, but the other two...:evil:
I'll need to remove approximately .5 mm to get every plug to flush out with the cam cover gasket surface.
...then blend the return-bevels to align with the cover end flats above.
These plugs polish up real nice. :)
  • daveo
  • Premium Member
  • Premium Member
09 May 2017 06:10 - 09 May 2017 10:17
#761532
Not sure about this, but it appears the gap at the base of the plug indicates that the curved head surface tapers away at the outside, so the plugs likely rest on the inside edge. If so, then this will assist to expel excess Hylomar (:)) sealant toward the outside where it can be cleaned off much-easier than inside where there is very-little access space next to the cams. :blink:
PITA x 4 = :evil:
Last edit: 09 May 2017 10:17 by daveo.
  • daveo
  • Premium Member
  • Premium Member
10 May 2017 09:15 - 11 May 2017 06:17
#761619
Whew, some project this [strike]was[/strike] is. :S
First try. Hopefully, no leaks for awhile. :whistle:
Last edit: 11 May 2017 06:17 by daveo.
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
10 May 2017 10:29
#761624
Nice!
Blue 1975 Z1B
Red 2009 Concours 14
  • daveo
  • Premium Member
  • Premium Member
10 May 2017 16:32
#761657
After the first ride...found a little oil drip at the bottom of half-moon #1. :pinch:
It crept around to the front of the plug, and was sitting there all proud of itself until I wiped most of the memory away with a rag. The cover gasket is sealed up nice, as are the three other plugs...:angry:
Wondering about using the cover gasket again...it's a plain OEM Kawasaki gasket with no graphite that should clean up well.
What should I wipe it down with?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 May 2017 17:06
#761660
Sorry to read about your failure with the half moons after all your hours of work and sweat.
What kind of liquid gasket do you use?
My half moons never do leaking after i have to do a little reshape with a key file in 1998 to get a little tight fit plus Hylomar blue.
My engine is dry like a dessert except the cam chain tunnel area and stator grommet.
