Idling issues when engine is warmed
- Kz250 enthusiast
21 Apr 2017 14:56
Hey Iv been having an issue with my bike, an 82" kz250 where it starts and runs fine until Iv been riding it for about 10-15 minutes then it starts to drop out when idling. It's fine if I keep giving it revs. But when I'm waiting at lights and stalls after a few seconds when I don't give it any throttle. Any ideas? Here's a photo of the spark plug
Re: Idling issues when engine is warmed
22 Apr 2017 06:29
Would suspect insufficient valve clearance as causing the reported symptoms.
The following user(s) said Thank You: GPz550D1, Kz250 enthusiast
- Kz250 enthusiast
23 Apr 2017 19:15
Thanks for the tip Patton, I went ahead and adjusted the valve clearances accordingly. They were too tight. It definitely starts heaps better now but the other problem still persisted when the engine gets hot. It also backfires and pops on deceleration
23 Apr 2017 19:16
Sync the carbs.
- Kz250 enthusiast
23 Apr 2017 19:21
Thanks Steve but it's only got one carb
23 Apr 2017 19:25
My bad. Popping can be a lean condition, timing, air leak or many other things. Pic of the plug?
- Kz250 enthusiast
- JR
23 Apr 2017 20:08 - 23 Apr 2017 20:09
Difficult to see in the avatar photo but is there an airbox on the bike and is that an open exhsust ?
Last edit: 23 Apr 2017 20:09 by JR.
- Kz250 enthusiast
23 Apr 2017 20:11
No the original air box has been replaced with a pod filter and did you mean open exhaust?
24 Apr 2017 04:33 - 24 Apr 2017 04:34
Popping from the exhaust on deceleration can result from a too lean pilot circuit, which might be due to the pod filter (as opposed to the stock air box with stock filter).
Could try turning the pilot screw 1/2 turn out, and test ride.
This presupposes that the stock anti-tamper plug covering the pilot screw has already been removed.
But if not, there's an easy method to remove it
Backfiring through the carb can result from a too tight intake valve clearance.
Last edit: 24 Apr 2017 04:34 by Patton.
- Kz250 enthusiast
27 Apr 2017 22:01
Problem solved: it was running lean. I adjusted the fuel screw and it idled way better now. Thanks heaps for the help
- rapfl
09 Oct 2018 05:32
Hi guys, I'm having a similar problem with my Z200. Could you describe how you adjusted the fuel screw? Did you just try different settings?
