Idling issues when engine is warmed
  • Kz250 enthusiast
  • Kz250 enthusiast's Avatar Topic Author
21 Apr 2017 14:56
#759816
Hey Iv been having an issue with my bike, an 82" kz250 where it starts and runs fine until Iv been riding it for about 10-15 minutes then it starts to drop out when idling. It's fine if I keep giving it revs. But when I'm waiting at lights and stalls after a few seconds when I don't give it any throttle. Any ideas? Here's a photo of the spark plug
Re: Idling issues when engine is warmed
22 Apr 2017 06:29
#759875
Would suspect insufficient valve clearance as causing the reported symptoms.
Good Fortune! :)
The following user(s) said Thank You: GPz550D1, Kz250 enthusiast
  • Kz250 enthusiast
23 Apr 2017 19:15
#760077
Thanks for the tip Patton, I went ahead and adjusted the valve clearances accordingly. They were too tight. It definitely starts heaps better now but the other problem still persisted when the engine gets hot. It also backfires and pops on deceleration
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Apr 2017 19:16
#760078
Sync the carbs.
  • Kz250 enthusiast
23 Apr 2017 19:21
#760079
Thanks Steve but it's only got one carb
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Apr 2017 19:25
#760080
My bad. Popping can be a lean condition, timing, air leak or many other things. Pic of the plug?
  • Kz250 enthusiast
23 Apr 2017 19:33
#760082
Here's one
  • JR
  • JR's Avatar
23 Apr 2017 20:08 - 23 Apr 2017 20:09
#760088
Difficult to see in the avatar photo but is there an airbox on the bike and is that an open exhsust ?
Last edit: 23 Apr 2017 20:09 by JR.
  • Kz250 enthusiast
23 Apr 2017 20:11
#760089
No the original air box has been replaced with a pod filter and did you mean open exhaust?
24 Apr 2017 04:33 - 24 Apr 2017 04:34
#760097
Popping from the exhaust on deceleration can result from a too lean pilot circuit, which might be due to the pod filter (as opposed to the stock air box with stock filter).
Could try turning the pilot screw 1/2 turn out, and test ride.
This presupposes that the stock anti-tamper plug covering the pilot screw has already been removed.
But if not, there's an easy method to remove it
Backfiring through the carb can result from a too tight intake valve clearance.
Good Fortune! :)
Last edit: 24 Apr 2017 04:34 by Patton.
  • Kz250 enthusiast
27 Apr 2017 22:01
#760450
Problem solved: it was running lean. I adjusted the fuel screw and it idled way better now. Thanks heaps for the help :)
  • rapfl
  • rapfl's Avatar
09 Oct 2018 05:32
#792067
Hi guys, I'm having a similar problem with my Z200. Could you describe how you adjusted the fuel screw? Did you just try different settings?
