Noise after starter clutch rebuild
- renomueller
16 Apr 2017 09:30
I had a starter clutch replaced and now the bike makes a noise in the lower unit. I was told by the dealer
that the starter clutch damper was destroyed and they went with the new damper. They say there are three(different sizes) so they went with the middle one. The noise sounds like a loose timing chain. Has anyone had a similar experience? The dealer says the damper just prevents the starter gear from free spinning after the starter is used. Thanks for any feedback......
- slmjim+Z1BEBE
Re: Noise after starter clutch rebuild
16 Apr 2017 10:37 - 16 Apr 2017 10:43
Hi Reno mueller,
What bike? If it's a 900 there's a specific, detailed process stated in the manual to determine the correct damper thickness. If the dealer mechanic "guessed" at the size needed he has a one-in-three chance of being right.
The damper prevents the starter gear from wobbling in its crank roller bearing.
EDIT: thread already in progress:
www.kzrider.com/forum/2-engine/605665-ru...tarter-clutch#759248
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 16 Apr 2017 10:43 by slmjim+Z1BEBE.
- renomueller
16 Apr 2017 10:58
The bike is a 1978 KZ1000, can you tell me if the damper is incorrect will it make a noise?
16 Apr 2017 12:46
If it's too thick the starter could be ruined.
The following user(s) said Thank You: GPz550D1, renomueller
