- Thank you received: 10
oil seepage
- DSummerlin
11 Apr 2017 21:12 #758994
by DSummerlin
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
oil seepage was created by DSummerlin
82 LTD 1000. hasn't been run in a couple of years. has been stored indoors, motor out of frame, empty of oil, and occasionally upside down. After a quick clean and paint refresh by member Zuki Dave, we've noticed this little seepage of oil. Figured I should present it to the forum for some sage advice on possible problem and possible solution.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
- Thank you received: 2063
11 Apr 2017 22:33 #758999
by Scirocco
Replied by Scirocco on topic oil seepage
Could be the camshaft end cap ( half moon ) is leaking.
To get on the safe site clean the area with brake cleaner and observe.
Michael
Michael
The following user(s) said Thank You: GPz550D1, DSummerlin
12 Apr 2017 04:16 - 12 Apr 2017 04:17 #759006
by Street Fighter LTD
Replied by Street Fighter LTD on topic oil seepage
Or copper washer under head nut is not sealing properly
Last edit: 12 Apr 2017 04:17 by Street Fighter LTD.
- DSummerlin
12 Apr 2017 14:04 - 12 Apr 2017 14:05 #759036
by DSummerlin
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Replied by DSummerlin on topic oil seepage
Will be looking at it this evening. BTW, u/scirocco, I just picked up a Scirocco a few months ago. It's an 84. It's a lot like my high school car from 30 years ago.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Last edit: 12 Apr 2017 14:05 by DSummerlin.
- zukdave
- Thank you received: 229
12 Apr 2017 18:33 - 12 Apr 2017 19:10 #759062
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic oil seepage
To me it looks like it's seeping around the oil galley plug behind the head bolt.
The bike had been on the side stand for a few days and went to the shop last night I found the oil.
Game plan for now is finish putting the bike back together and see what happens when we fire it up.
If it pushes oil out while running I guess the head will need to come off should be no big deal to pull the plug and tap the hole for a threaded plug.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 12 Apr 2017 19:10 by zukdave.
13 Apr 2017 00:50 - 13 Apr 2017 01:06 #759078
by Scirocco
The oil galley plug behind the head bolt is a press fit aluminum plug.
Before i would remove the head i would try to do a little light hit with a drift punch to stop the leaking.
If you pull the plug(s) you can do a oil line mod like this
Michael
Michael
Last edit: 13 Apr 2017 01:06 by Scirocco.
- DSummerlin
13 Apr 2017 11:01 #759110
by DSummerlin
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
I was hoping someone would suggest a light tap with a drift punch. I REALLY don't want to remove the head again.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
- Thank you received: 2749
13 Apr 2017 11:40 #759115
by SWest
Replied by SWest on topic oil seepage
I've never seen them leak there. Sure it's not the cam end caps?
- DSummerlin
13 Apr 2017 14:09 - 13 Apr 2017 14:10 #759125
by DSummerlin
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Not sure about much these days. i suppose we'll see (or not) when we fire it up.
Backstory- i've had the head freshened up with new valves/springs, and guide seals so all new gaskets/o-rings from head gasket up and new cam end caps as well. New copper washers, too.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Last edit: 13 Apr 2017 14:10 by DSummerlin.
13 Apr 2017 14:15 #759126
by SWest
I guess it could be leaking there and it should be obvious once running.
The following user(s) said Thank You: DSummerlin
- DSummerlin
13 Apr 2017 14:23 - 13 Apr 2017 14:23 #759127
by DSummerlin
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Also, it still has no oil besides what was left from draining it a couple of years ago, so it's extra weird that it even wants to leak.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
Last edit: 13 Apr 2017 14:23 by DSummerlin.
13 Apr 2017 14:38 #759132
by SWest
I'm not sure they are aluminum. I always thought they were steel. Scratch one to see. You could try to peen the outside with a socket or steel tubing that size if so. I wouldn't try to drive it in for fear of making it worse.
