Scraping or sliding noise only during acceleration
  • Setton
  • Setton's Avatar Topic Author
05 Apr 2017 06:34
#758528
So on my bike, for a while now I've been hearing a scraping or sliding noise that occurs only while the throttle is being applied. No matter what velocity I'm going, if I'm not applying throttle, I can't hear it. It also only happens when the gears are engaged, never in neutral or with the clutch lever pulled in.
KZs I own
1982 KZ750-H3 LTD (frame's bent, no longer rideable, RIP)
1982 KZ1100 LTD Shaft (thought it was a Spectre)
1988 KZ1000 Police
1989 KZ1000 Police (basket case)
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
I don't understand soup. Put a flower on my nose.
Re: Scraping or sliding noise only during acceleration
05 Apr 2017 07:01
#758534
Check the drive chain adjustment using the Kawasaki Service Manual as your guide. Too lose or too tight is not good. Ed
  • Setton
05 Apr 2017 07:38
#758537
Chain drive is fine.
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
05 Apr 2017 09:01
#758545
Ed may still be on the right path. Could be hitting inside the engine sprocket cover
What is your gearing compared to stock.???
I had a rub there when I went to 16 tooth front on my 1000 vs 15 tooth stock gear
Wont hurt to check
Dave B) B) B)
  • KZB2 650
  • KZB2 650's Avatar
05 Apr 2017 10:39
#758549
Maybe put it on the center stand and spin the wheel..... I need to get the chain guard just right or it scraps.... hope its not in the motor.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Setton
05 Apr 2017 11:06 - 05 Apr 2017 11:10
#758552
If that were the case, wouldn't the sound happen regardless of whether or not throttle is being applied?
It is stock...
I only hear it when both of two conditions are met... 1: the bike is in motion, 2: throttle is being applied. If I let go of the throttle, I don't hear it. If I push the bike in neutral with it off, I don't hear it. If I put the bike on the center stand, turn the bike on, and apply throttle, I don't hear it... Both of those conditions have to be met...
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
Last edit: 05 Apr 2017 11:10 by Setton.
05 Apr 2017 12:48 - 05 Apr 2017 12:50
#758562
No.
Consider this -
When the throttle is being applied with the tranny in gear the engine sprocket is pulling the top length of the chain taut as it pulls on the drive sprocket. When that happens all the slack in the drive chain ends up on the bottom length of the chain. This extra slack in the bottom length of the chain can cause the chain to rub things if the chain has too much slack in it.
One word of caution though - do NOT adjust the chain such that there is no slack in it. Doing that will very quickly ruin a chain because it needs some slack to cope with the fact that as the rear axle rises to a point where the axle, engine sprocket center, and swing arm pivot are aligned the distance between the sprockets increase. If the chain is adjusted with insufficient slack the chain will stretch and be damaged. Be sure to follow the instructions in the Kawasaki Service Manual or the bike's Owner's Manual for adjusting the chain. Ed
Last edit: 05 Apr 2017 12:50 by 650ed.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
05 Apr 2017 13:03
#758565
Hello
Do you have checked the rear wheel bearings and the bearing in the rear sprocket hub ?
Under acceleration a worn out bearing can cause a scraping or sliding noise (dry bearing without grease).
Michael
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Apr 2017 19:18
#758584
Loose sprocket?
  • dkoz
  • dkoz's Avatar
06 Apr 2017 10:23
#758630
When setting on your bike putting weight on the seat that is that will cause more slack in your chain. Is it possible that this is why you do not hear it when it's on the center stand?
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • peter1958
  • peter1958's Avatar
