83 kz550m1 - shaft transmission question
- 83550m
01 Apr 2017 03:42
It's only happened twice in 850 miles but when accelerating thru the gears the up-shift from 3rd to 4th I suddenly find myself revving in neutral.Any idea's what may cause this and /or things to check?
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
Re: 83 kz550m1 - shaft transmission question
01 Apr 2017 04:48
It may be that those 2 times you just didn't kick the shift pedal firmly enough. or maybe you shifted early or late while the clutch was still engaged. ??? if it's not that, then there may be a problem with the gear change drum & forks. The service manual may have a list of possibilities in the troubleshooting section. the 81 650 manual does at the end.
How long have you had the motorcycle & have you changed the oil?
- 83550m
02 Apr 2017 07:05
How long have you had the motorcycle & have you changed the oil?[/quote]
I just bought this bike at the beginning of this year ... oil and filter was changed and filled with shell rotunda 10w-40 diesel spec etc
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
02 Apr 2017 11:02
Finding false neutrals is not uncommon with old bikes like ours. It's hard to say whether or not it's normal or not. There is some variation from bike to bike and model to model. One thing I can say is that if your clutch is dragging too much that can exacerbate the issue. Wearing the right type of boots and adjusting the shift lever so you can deliberately be sure to throw the lever firmly and full stroke can help.
- loudhvx
03 Apr 2017 08:35
The (chain) 550's all seem to have an easily-found, false-neutral between 5th and 6th, I don't think I've ever found a false neutral between 3rd and 4th on any 550. I can't say whether a shaft drive would be different from a chain. I've mostly dealt with chain-drive bikes.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
03 Apr 2017 19:00
The shift drum pawl keeper disk may be loose.
- 83550m
02 Aug 2018 13:49
Update : I've put about 10K miles on this bike since this initial post and just wanted to add that i have pretty much solved the problems with the false neutrals just by modifying my riding Technique.... when shifting i hold my foot up firmly on the shift lever after each shift for extra few seconds and let off after rolling on the throttle . now it's like second nature ... no more false neutrals ... hope this may help someone.
1978 kz650 b2
1980 kz440 b1
1983 kz550m LTD
1980 kz440 b1
1983 kz550m LTD
02 Aug 2018 13:55
Weak return spring.
The following user(s) said Thank You: 83550m
