KZ1100 valve adjustment question
  • 76KZ900
  • 76KZ900's Avatar Topic Author
21 Feb 2017 00:37
#754730
It's been a few years since I've done the valve adjustment on a KZ, but i seem to remember that one side either intake or exhaust was normally the side needing shims more than the other .. Of course I'll check them all but just wondering. Also who has shims best price now a days ?
Valve cover is out being chromed now and i wanted to get started on valves on my days off.
Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: KZ1100 valve adjustment question
21 Feb 2017 05:24
#754733
1982 KZ1100-A2/1170 sleeper 😀
  • 76KZ900
22 Feb 2017 03:51
#754808
Thanks Dave
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • zed1015
  • zed1015's Avatar
22 Feb 2017 04:42
#754810
As with all engines the exhaust valves have a harder life and are more prone to wear so you may find that those have tighter clearances.
When re-shimming try and get the figures towards the upper 0.15mm end of the scale if possible and never below the 0.10mm minimum.
  • Kitten Tooth
  • Kitten Tooth's Avatar
22 Feb 2017 09:44 - 22 Feb 2017 09:44
#754833
I went to my local cycle shop for shims when i adjusted them on my 81' KZ1000. I think they darn near gave them away to me. Im sure there are cons to getting used shims but they worked for the job all the same.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 22 Feb 2017 09:44 by Kitten Tooth.
  • Zen Shenron
  • Zen Shenron's Avatar
22 Feb 2017 14:00
#754856
Not saying I have not used the K&L Shims Jeff at Z1 sells, but I prefer using oem shims.
Those K&L shims were having QC issues not to long ago if I remember correctly.
Charles
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Feb 2017 15:43
#754873
I've had a couple come apart. OEM is best.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
22 Feb 2017 15:51
#754874
Zen Shenron wrote: Not saying I have not used the K&L Shims Jeff at Z1 sells, but I prefer using oem shims.
Would that have been in the last year or so, and what was the main QC issue with them? I remember Z1E was having trouble getting shims in-stock a year or so ago...:blink:
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
22 Feb 2017 15:52
#754875
swest wrote: I've had a couple come apart. OEM is best.
What!!!:ohmy:
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Feb 2017 15:56
#754877
The hard facing was coming apart. No maker marks on them so no telling where they came from.:unsure:
  • Zen Shenron
23 Feb 2017 09:20
#754977
If I remember it was 2 or 3 years back, some of the shims were not within production tolerances.
Charles
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
  • 76KZ900
24 Feb 2017 22:29
#755153
Got adjustment done. Had enough factory shims from previous bikes to get them. Two of my intakes were real tight.. One I could barely turn with my fingers so it was way too tight. Also heli coiled one valve cover bolt. Now as soon as valve cover gets back from chrome shop I'll be in business.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
