Is this cam shaft done for?
  • Jekyll86
  • Jekyll86's Avatar Topic Author
01 Jan 2017 15:40 - 01 Jan 2017 15:55
#751110
Hello gents,
I acquired a set of gpz750 cams on the interwebs yesterday. A bit of reading provided mixed reviews on installing used cams; some say finding a set of used gpz750 cams is the way to go and others say used cams are a poor decision all the way around. I found both in and ex cams for $40, so I jumped on it and figured I could decide later if I'll install them. I would love the collective opinion on the condition of the cams before i do anything with them (or return them).
The intake cam looks pretty good. My concern here is a small scuff on the #4 lobe that is barely noticeable with a fingernail run across it.
Attachment image2-2.JPG not found
The ex cam doesn't appear serviceable. Lobe #3 has a 1mmx2mm nick and a 1mm-ish nick on the very edge of the lobe.
Attachment image1-2.JPG not found
I'm bummed that the cams aren't as noted in the add, but the seller feedback was 99% and they were only $40, so I figured the gamble was worth the try.
Any thoughts on whether or not they should be used?
1984 KZ700A1 Franken-saki 810 kit
1976 KZ400 broken-saki
1981 KZ750B
2018 z900rs
Last edit: 01 Jan 2017 15:55 by Jekyll86.
  • Jekyll86
Re: Is this cam shaft done for?
01 Jan 2017 15:50 - 01 Jan 2017 15:57
#751112
1981 KZ750B
2018 z900rs
Last edit: 01 Jan 2017 15:57 by Jekyll86. Reason: fixed the original post
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jan 2017 17:14
#751120
Doesn't look like they're worn past the hard facing. They may be useable with a little clean up.
  • Jekyll86
01 Jan 2017 18:37
#751127
Thanks swest. Now that I'm thinking through it, I think My main concern is whether or not it will damage the tappets.
1981 KZ750B
2018 z900rs
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jan 2017 18:49 - 01 Jan 2017 18:49
#751129
As long as there are no high spots or the lobes are square, it should be good to go.
Last edit: 01 Jan 2017 18:49 by SWest.
  • Nessism
  • Nessism's Avatar
01 Jan 2017 19:46
#751134
The tappet buckets are dime a dozen. No big deal other than you will have metal debris in the motor for the filter to clean up.
