Sprockets
- Zachgrove1
Sprockets
28 Dec 2016 13:59
Hello all, hope everyone had a great holiday season!
In the process of rebuilding a 1981 Kawasaki KZ1000 LTD running stock forward and rear sprockets, and was wondering if I changed out the sprockets if it would increase performance? Looking for more of a low to mid range increase in performance.
Any advice and input on ratios welcomed!
Re: Sprockets
28 Dec 2016 16:58
What do you have now?
- MDZ1rider
Re: Sprockets
29 Dec 2016 07:32
A smaller front (counter)/larger rear sprocket will lower your over all gear ratio. This will give you quicker acceleration at the expense of top end speed. If you do a lot of stop/go city type riding, this may be a good thing. If you primarily ride open or freeway type roads at sustained higher speeds, it may be a bad thing.
Since you are in the rebuilding process, I wouldn't worry about the gear ratio just yet. Get the bike running, ride it for a while, and then decide if a change is needed based on your riding habits. The stock KZ1000 acceleration is adequate for most types of riding. Changing sprockets later is a relatively simple process.
