Exhaust Flange Fabrication
  • TBurglar
  • TBurglar's Avatar Topic Author
23 Nov 2016 20:57
#748802
Has anyone tried to fab up an exhaust for a 650 and successfully made the flat flanges that the split collars push against? I'm trying to figure out how I would even do it, so I can make my own exhaust.
"Courage is rightly esteemed the first of human qualities because it is the quality which guarantees all others." -Winston Churchill
  • TexasKZ
  • TexasKZ's Avatar
Re: Exhaust Flange Fabrication
23 Nov 2016 21:03
#748803
I think the easiest way is to get a length of tubing that has an i. d. that matches the o. d. of the pipe and weld a slice of it to the pipe. An alternative would be to machine rings and weld them on.
  • DoctoRot
  • DoctoRot's Avatar
24 Nov 2016 00:16 - 24 Nov 2016 00:18
#748809
I machined some collars out of 6061 for the custom header on my 750 twin.
If you don't have access to a mill you could have them laser/waterjet cut from sheet pretty easy
Last edit: 24 Nov 2016 00:18 by DoctoRot.
  • TBurglar
24 Nov 2016 07:24
#748826
Thanks guys. How does the custom flange work DoctoRot? I think I will go with the pipe on pipe method TexasKZ suggested, but alternative solutions are always a good thing.
  • DoctoRot
  • DoctoRot's Avatar
24 Nov 2016 11:44 - 24 Nov 2016 11:47
#748840
I machined all the parts myself because I had never done anything like this before and wanted to try it out, but you can achieve it In a simpler fashion. The collar slides over the exhaust spigot which has a ring sticking out. The retaining rings fit behind this and fit into a bored out step in the collar.
An easier way would be to have the collars waterjet cut and put them on the exhaust tube before you weld the larger pipe on the tip like texaskz suggested. The only bummer with this is the collars are permanent unless the primaries are slip On.
Last edit: 24 Nov 2016 11:47 by DoctoRot.
  • Nessism
  • Nessism's Avatar
24 Nov 2016 11:59
#748842
Why not use the collars from a 750/4 bike along with the half moon pieces? All you have to do then is add a doubler piece that slips over the pipe and butts against the head. Basically, same method as the OEM pipes use.
  • undiablo
  • undiablo's Avatar
25 Nov 2016 07:01
#748878
It might be usefull for some of you guys:
Attachment Header1.jpg not found
Attachment Header2.jpg not found
Attachment Header3.jpg not found
Attachment Header4.jpg not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
The following user(s) said Thank You: rstnick, peter1958
  • TBurglar
26 Nov 2016 16:06
#749002
What is that tool called undiablo?
  • TBurglar
26 Nov 2016 16:25
#749004
I definitely don't have the equipment to drill a 1.4" hole in steel that thick, but it does seem like the best option, if I could find one somewhere.
  • Jussumguy
  • Jussumguy's Avatar
26 Nov 2016 19:21
#749018
Yeah I always just hack up a trashed set of old pipes. Why reinvent the wheel. Also it makes for some keen reversion tubes. Helps scavenge exhaust they say.
