KZ900 A4 FRUSTRATED- Can't get valve timing right
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ900 A4 FRUSTRATED- Can't get valve timing right
01 Nov 2016 08:35
#746836
They should be pointing away from each other. That's when you adjust the valves.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
01 Nov 2016 08:40
#746837
We've never paid any attention to the 28th tooth mark on the cam chain itself after the initial install. We only use it for the initial cam timing setup. As long as the T mark and cam sprocket timing alignment marks agree every two crank revs all should be good. Turn by hand ten or so revs to confirm no valve interference.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Katums
  • Katums's Avatar Topic Author
01 Nov 2016 08:42
#746839
Now I'm really confused. I apologize, but I think I read that the lobes on #4 should be pointing to each other and those on #1 opposed when at TDC.
I'll get some pictures to you as soon as I totally redo the cams again and check everything out.
This is my 7th redo...........I've never gotten stuck like this with another machine.
1976 KZ900 A4
2003 Porsche Boxster S
  • Katums
01 Nov 2016 08:46
#746840
Ya know, I wondered about that. In fact, I have had correct 28 pin alignment after the first full rotation to TDC. If you are correct, and I sure hope you are, I've had the thing timed a few times.
I'm going now to redo everything and will report back.
Thank you for your kind response.
1976 KZ900 A4
  • Katums
01 Nov 2016 10:04
#746846
Can anyone else confirm that pin 28 will stay on the mark for only the first 2 revolutions?
This makes sense to me, given my 8 do-overs.
Thanks to all for the valued input!
1976 KZ900 A4
  • zed1015
  • zed1015's Avatar
01 Nov 2016 10:41
#746857
The 30 teeth of the cam sprocket doesn't divided equally by the 122 links of the cam chain - simple.
The pin you have marked as 28 won't stay in the same spot on each rotation and will drift further and further off it's initial location each time you bring the timing marks back to TDC.
At least it's given you the opportunity to perfect the timing procedure :laugh:
  • Katums
01 Nov 2016 12:00
#746873
Exactly, I have it down now for sure. And. The explanation makes sense. Logic had me leaning toward that explanation, but I wasn't confident and didn't want to lunch the valves.
Next on my agenda are the carbs. I want to open them up and clean them.
This poor machine had a very tough life until I hauled it out from under the dudes deck where it sat for 15 years. Its solid and well designed and built. It will live to ride again!
Thanks for the help, it is very much appreciated.
1976 KZ900 A4
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Nov 2016 12:14
#746878
Adjust the valves before going to the carbs.
  • slmjim+Z1BEBE
01 Nov 2016 12:23
#746882
zed1015 wrote: The 30 teeth of the cam sprocket doesn't divided equally by the 122 links of the cam chain - simple.
That's a good explanation. Well said.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • missionkz
  • missionkz's Avatar
01 Nov 2016 18:14
#746913
Right! Marks on the chain are meaning less once you count over 28, hook it into the gullet. And clamp the cam down. Once you rotate the crank 360-720 degrees there will still be 28 pins apart from the > mark on the exhaust to intake, but it will be a different 28 pins on the chain.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Katums
02 Nov 2016 04:51 - 02 Nov 2016 04:52
#746932
Yes, valves adjusted before carbs. I'm hoping I won't need to order shims, but I'm guessing I will. Valves today.
Is it common to need different sized (thickness) shims for each valve?
Would you recommend renewing carb kits or should cleaning be sufficient? I took off the top and bottom caps just to inspect and they are crusty with white residue.
1976 KZ900 A4
Last edit: 02 Nov 2016 04:52 by Katums.
  • Katums
02 Nov 2016 04:56
#746933
Yep, now I know.
One would think that either the OEM shop manual or Clymer would have noted that the 28 pin mark is good only for the initial rotations.
Thanks everybody!
1976 KZ900 A4
