What have I got??
- McZed
What have I got??
30 Oct 2016 05:36
I would seem to be a sucker for old Kawasaki's. I have a Z1300, 6 cylinder, and after months of work I have finally got it running as should. It's a big heavy old beast but it's a blast to ride. So, being a glutton for punishment I have just bought what I think is a 1982 Kawasaki kz 1000.
The engine number is KZT00JE009315. and the frame number is JKAK2CJ13BA002355.
Can anyone tell me exactly what I have, and if it will be worth restoring?
- Mcdroid
- Gone Kwackers
Re: What have I got??
30 Oct 2016 06:02 - 30 Oct 2016 06:05
You apparently have a 1981 KZ1000-J1 Standard . This is based on information posted on
www.zedder.com
. As for whether or not it is worth restoring...that will be up to you...I'd restore it...but some view me as unusual. There is not much value associated with restored early J models.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 30 Oct 2016 06:05 by Mcdroid.
The following user(s) said Thank You: McZed
- GPzMOD750
30 Oct 2016 06:10
Pics????
For some reason, I am staying in the 1982 model year. They are a bit different the 81-85 years. They were odd for most motorcycle companies a ton of different things were tried, not quite the traditional 60-70s bikes but not yet the modern looking and running bikes since. The most annoying thing to me in that time period are the 85 mph speedos. Luckily, the only other country that used the mph speedo, the U.K., didn't prescribe to that foolishness and you can get a proper speedo from there.
- barney
30 Oct 2016 09:33
I'm a sucker for kz1000j's. Great bikes. Eddie Lawson and Rob Muzzy among others were very successful racing them for mother Kawasaki. I wouldn't sell my J3
- dvnsta
30 Oct 2016 10:14
Good to know on the speedo going to find myself one.
1982 KZ 750 LTD H3 stock except with custom seat skin and kawasaki period backrest.
Kawasaki 1989 eliminator 250 b3
- barney
30 Oct 2016 10:26 - 30 Oct 2016 10:28
A couple of J's for inspiration. I'm not sure if I totally agree with McDroid on this one. I've seen well restored J's go for big dollars
Barney
Barney
Last edit: 30 Oct 2016 10:28 by barney.
- McZed
30 Oct 2016 11:02
Thank's for the info, I thought I had bought a bit of a mixture. Wasn't sure if the engine and frame belonged together. It's seems to be in a reasonably original condition. It needs the starter clutch replaced, the guy I bought it from tried to fix it himself, he gave the flywheel a good pounding with a hammer, so the magnets are all broken. I have ordered a new starter clutch kit, if anyone knows where I can get another flywheel can they please let me know, or if anybody has one for sale I would be very grateful.
Please brace yourselves for a bunch of stupid questions while I attempt to get it running.
:lol:
:lol:
- GPzMOD750
31 Oct 2016 04:27 - 31 Oct 2016 06:32dvnsta wrote: Good to know on the speedo going to find myself one.
They aren't the easiest things to find but they are out there. They are the same for the 81 & 82 KZ1000J, KZ1100A and the KZ1000R (ELR). In 83 they went to a different set up. You might be able to use a KZ1100B GPz panel but it is the one piece box type unit but it also has a volt meter. Of course, the best way to find the stuff in the UK is to drop the "K" from the designation ie. "Z1000J".
McZed wrote: Thank's for the info, I thought I had bought a bit of a mixture. Wasn't sure if the engine and frame belonged together. It's seems to be in a reasonably original condition. It needs the starter clutch replaced, the guy I bought it from tried to fix it himself, he gave the flywheel a good pounding with a hammer, so the magnets are all broken. I have ordered a new starter clutch kit, if anyone knows where I can get another flywheel can they please let me know, or if anybody has one for sale I would be very grateful.
:lol:
If you find you need a starter don't get the stock one. Find the starter for an early 80s Honda CB900 They fit if you rotate the casing and they are 0.8 kw (~1 hp) as opposed to the Kawi 0.6 kw (~.80 hp) starter. Even the CB750 starter is 0.7 kw.
Last edit: 31 Oct 2016 06:32 by GPzMOD750.
