How Do 81 Cam Tensioner Slides Fit?
- TBurglar
29 Oct 2016 09:00 - 29 Oct 2016 18:17
I bought an 81 KZ650 csr as a basket case, and I can't figure out how the slide with the pin fits. The other one isn't a problem, but the pin is clearly too short to go in the slots between the head and the tubes. Does this mount between the tubes and the crankcase? Does anyone have a picture of how it mounts? Thx
-TBurglar (Nick)
-TBurglar (Nick)
"Courage is rightly esteemed the first of human qualities because it is the quality which guarantees all others." -Winston Churchill
Last edit: 29 Oct 2016 18:17 by TBurglar.
Re: How Do 81 Cam Tensioner Slides Fit?
29 Oct 2016 16:46
Do you have a manual? Pics?
29 Oct 2016 17:55
- TBurglar
29 Oct 2016 18:22 - 29 Oct 2016 18:25
I am familiar with that diagram, but it doesn't help me. I am trying to figure out where that pin sits. I'm assuming it is in the crankcase, but that hasn't been confirmed.
I have a manual, but it doesn't have a diagram or instruction on where that pin sits.
Last edit: 29 Oct 2016 18:25 by TBurglar.
29 Oct 2016 18:26
What pin are you referring to?
- TBurglar
29 Oct 2016 20:58
On the link 650ed posted, it is part# 39115 and is labeled shaft, cam chain guide.
-Nick
-Nick
29 Oct 2016 21:03
That goes between the case and barrels. You need the rubber dampeners too.
- TBurglar
29 Oct 2016 21:10
Great! Thanks for confirming.
-Nick
-Nick
- rrsmsw9999
30 Oct 2016 04:49 - 30 Oct 2016 04:50
Use assembly lube or case sealer to hold the rubbers in place while assembling, they will stay put during assembly. Otherwise they are easy drop down the cam chain channel. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 30 Oct 2016 04:50 by rrsmsw9999.
