Autolite Iridium spark plugs. Opinions?
- tomsbadkz
18 Oct 2016 12:33
I know that most use the NGK BR8ES spark plugs. Whats the advantage or disadvantage of running Iridium spark plugs?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: Autolite Iridium spark plugs. Opinions?
18 Oct 2016 13:10 - 18 Oct 2016 16:21
Iridium plugs are designed to last for a long time. There are different brands and grades of iridium plugs which vary in durability, so the devils in the details, but the best grades will literally run 100,000 miles in a car. The issue with running them in an old motorcycle is that most are resistor type, and you don't want to run a resistor plug if you are using a resistor type spark plug cap such as came on our bikes. And speaking of spark plug caps, you need to get plugs with the proper top to match with your caps. The OEM resistor caps need plugs with a threaded top, and not all iridium plugs are sold that way.
I bought a set of NGK Iridium IX : BR8EIX plugs for my bike and ran them briefly before realizing they are resistor type so they were removed. If you can use them I'll make you a good deal.
Last edit: 18 Oct 2016 16:21 by Nessism.
- slmjim+Z1BEBE
18 Oct 2016 13:13
Google is your friend. Decide for yourself.
www.sparkplugs.co.uk/iridium-spark-plugs
en.m.wikipedia.org/wiki/Iridium
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- tomsbadkz
18 Oct 2016 15:45 - 18 Oct 2016 15:45
I'm using Dyna S 8mm wires which work with standard plug tips. The BR8ES is a resister plug,right?
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Last edit: 18 Oct 2016 15:45 by tomsbadkz.
18 Oct 2016 15:55
Yes. Are the wires resistor too?
- tomsbadkz
18 Oct 2016 16:23
Running the DW800 wires
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- zukdave
18 Oct 2016 16:53
I think the only thing that'd run better would be the money leaving your wallet.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
18 Oct 2016 17:49tomsbadkz wrote: Running the DW800 wires
With those wires you don't need resistor plugs.
18 Oct 2016 17:55
- DFIGPZ
18 Oct 2016 21:26
I use them as much as possible.
1984 750 Turbo
- tomsbadkz
19 Oct 2016 01:59
Cool. Thanks. Hey B. I'm still gonna get with you about motor. I just got back to work after a fall there breaking my tailbone and banging up my left elbow. Workers comp money isn't that good. Was off for 4 1/2 months. Ouch.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
