Valve Adjustment Tools
- johnnymoff
26 Sep 2016 06:17
Is it worth getting a shim changing tool? If so, then does anyone have an opinion on which of these to get, i.e., is the more expensive one worth it?
www.z1enterprises.com/product/ZSM001-113
www.z1enterprises.com/product/TU15-0468
BTW, This will be my first valve adjustment, ever. I am assuming that one of these tools will make the job more efficient and less complex due to not having to remove the cams.
Thanks,
-John
Thanks,
-John
Engine: 77 KZ1000 A1
Frame: 78 KZ1000 B2
Carb Type: VM 26 with accelerator pump.
Needle clip: 3rd (middle) position
Pod air filters
Main Jet 132.5
Idle Jet 20
Clip position on needle 3rd (middle)
Exhaust 4 into 1 Vance and Hines
PO says 1170 kit installed.
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
Re: Valve Adjustment Tools
26 Sep 2016 06:25
John,
Please add your bike's year and exact model to your signature line as it will help folks answer questions accurately. Depending on which model bike you have a shim tool may or may not be appropriate. Ed
26 Sep 2016 06:35
If you have a small four they won't work. I like the first one but there's a danger of bending a valve if you turn the crank the wrong way.
26 Sep 2016 07:48
For shim over bucket adjustment you can use a large zip tie instead of purchasing a tool. Lots of guys swear by this method over using the bucket depressing tools.
- johnnymoff
26 Sep 2016 07:54
I have a KZ1000. Based on the block number, it is a '77a1. I believe this would be the shim over bucket, right?
Do I need to take the head off to use the zip tie method?
Also, I am using specs from an A2A manual, are they the same as the A1?
Thanks,
-John
Thanks,
-John
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
26 Sep 2016 08:05
I don't trust that method. Yes on the others. The factory style tool is the best.
The following user(s) said Thank You: johnnymoff
26 Sep 2016 08:18 - 26 Sep 2016 08:19johnnymoff wrote: I have a KZ1000. Based on the block number, it is a '77a1. I believe this would be the shim over bucket, right?
Thanks,
-John
No, you do not need to remove the head. Read about it here... members.dslextreme.com/users/bikecliff/i...lve_tool_zip_tie.pdf
Last edit: 26 Sep 2016 08:19 by Nessism.
- Kapahulu
26 Sep 2016 13:46
I have changed shims with the zip tie method. It's easy and cheap. Besides your normal shop tools, all you need is a big zip tie.
2strokeworld.com
2strokeworld.com
- johnnymoff
26 Sep 2016 13:52
Thanks Guys!
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
- rrsmsw9999
26 Sep 2016 13:58
Zip tie works great, you do need to measure the shims you have to know what ones are needed to swap or switch out. Check all clearances first. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Dr. Gamma
27 Sep 2016 11:23The factory tool #T57001-113 is THE BEST, end of question. Its quick, easy, and works the best!!! Been using one since 1973 on Z's and KZ's. Just take the spark plugs out, and turn the motor over using the 17mm nut on the advancer side of motor. Just make sure you NEVER use the electric start to move the cams, or you will see your shim tool laying on your lift with part of the cylinder head still attached!!! There is no way you can tag a valve using that factory tool.swest wrote: I don't trust that method. Yes on the others. The factory style tool is the best.
Years ago in a Kawasaki dealership, I watched some hot shot Z1 know it all mechanic rip a large chunk out of a Z1 head using the electric start with the shim tool. I had a hard time to keep from laughing in his face after watching that happen!!!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: SWest, Kray-Z, johnnymoff
- car5car
- Banned
29 Sep 2016 01:14
I made a tool from table knife with metal handle. It took about 20 min or so.
96 Yamaha Royal Star
82 Yamaha Virago 920
