Exhaust Split Collar / Keeper Spacing
  • FrankenKZ650
  • FrankenKZ650's Avatar Topic Author
20 Sep 2016 10:01
#742981
Hello,
Did some searching and did not see any related topics - I'm wondering if the split keeper spacing / position matters when installing an exhaust / header? On my kz1000, i noticed the "split keeper" spacing is not equal on all the pipes. My #3 cylinder has the keeper nearly touching on one side, with a larger gap on the other. I'm talking about the pieces that actually seat the pipe to the head, not the circular "clamp" that holds it all together. Am I over-thinking this?
Thanks!
Dustin
1977 KZ650 (1982 KZ750-4 Engine)
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
  • martin_csr
  • martin_csr's Avatar
Re: Exhaust Split Collar / Keeper Spacing
20 Sep 2016 10:17 - 20 Sep 2016 10:41
#742983
As long as the exhaust system is mounted securely & there are no leaks, you'll be fine.
I try to install the half-moon exhaust collars evenly & with the gaps between the mounting studs.
Last edit: 20 Sep 2016 10:41 by martin_csr.
The following user(s) said Thank You: FrankenKZ650
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
20 Sep 2016 17:20
#743029
I've heard some folks use scotch tape to keep the split collars and exhaust gaskets in place while installing them, taped to the head pipes. The tape burns after start up.
I've never done this, as I don't want to clean off burnt tape from my pipes. But I have heard of it many times....
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Sep 2016 17:25
#743031
Masking tape.
  • missionkz
  • missionkz's Avatar
20 Sep 2016 22:56
#743053
swest wrote: Masking tape.
Correct.
And the tape, if install d right, never touches the pipes so I don't understand the comment about keeping it off the pipes
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • westmiltonfab
  • westmiltonfab's Avatar
21 Sep 2016 06:23
#743068
Steve's right. Masking tape makes it so easy.
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
  • FrankenKZ650
21 Sep 2016 06:26
#743070
Thanks, Martin.
I know the tricks to install them, but some of my keepers shifted before I tightened the nuts.
I have a spare set of coppers, so I might give it a go with better rubber bands this time around.
Thanks for the replies!
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
  • Kray-Z
  • Kray-Z's Avatar
21 Sep 2016 16:09
#743129
Correct.
The ones I had to clean with wire wheel had burnt tape, several layers of tape, on the split collars, the clamping collars, head pipes, and the pipe end flanges.
I've never had to use tape to do this......I just know lots of people do, and I've seen some results that I didn't appreciate very much....same goes for using RTV in place of gaskets. I don't like cleaning up after someone else's RTV "party" either....
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Sep 2016 16:22
#743133
Too much is just too much. :whistle:
