81 KZ1100 A1 strange oil leak
  • Fire ranger 18
  • Fire  ranger 18's Avatar Topic Author
18 Sep 2016 13:40
#742758
I rebuilt the top end a little over a year ago and about 5500mi. I have to add about 1qt of oil every 400mi. I have a little seepage at the cam end plugs but on the txt front stud hole/oil galley there is oil. Not at the head or the base of the cyl just the middle. Is it possible that I have a crack here? Just a really odd place for a crack.
81 KZ1100 A-1
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: 81 KZ1100 A1 strange oil leak
18 Sep 2016 17:23
#742769
pics would help. With that much loss you have a problem. Gasket failure maybe. Did you retorque the head after rebuild and running for about 500 miles? That much loss points to a bad seal such as oring in head, oil pan orings or some other major spot. Does it smoke such as burning oil past the rings? My 0.02$ R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Fire ranger 18
18 Sep 2016 17:58 - 18 Sep 2016 18:00
#742774
rrsmsw9999 wrote: pics would help. With that much loss you have a problem. Gasket failure maybe. Did you retorque the head after rebuild and running for about 500 miles? That much loss points to a bad seal such as oring in head, oil pan orings or some other major spot. Does it smoke such as burning oil past the rings? My 0.02$ R
I just washed it again trying to get a better location. I'll try and take some pictures when I get home from work tomorrow. I have retorqued the head bolts twice. It smokes a little on start up but it's not noticeable after a few seconds.
81 KZ1100 A-1
Last edit: 18 Sep 2016 18:00 by Fire ranger 18.
  • missionkz
  • missionkz's Avatar
18 Sep 2016 18:17
#742775
1qt every 400 miles??!
Unless you have a 3"-4" puddle under the bike every time you shut it off and park, you have bad valve guide seals and or bad oil control rings on the pistons.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Fire ranger 18
18 Sep 2016 18:31
#742776
No puddles. I replaced the valve seals and rings last year. It's possible that I got substandard parts or messed up something on reassembly. I'm used to slightly bigger parts in a diesel lol
81 KZ1100 A-1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
18 Sep 2016 20:43
#742792
I read that somewhat excessive oil use was typical with 1100 engines, but don't recall what was/is considered acceptable. :S
Anybody know?
1982 KZ1100-A2/1170 sleeper 😀
  • Fire ranger 18
19 Sep 2016 18:32
#742942
So I may have found a larger leak but I'm still confused as to how oil is getting in the middle of the right front oil passage of the jug.
81 KZ1100 A-1
  • ajsfirehawk
  • ajsfirehawk's Avatar
20 Sep 2016 08:37
#742980
That is a head gasket leak but it isn't giving up nearly enough oil to be the problem. My 83 KZ1100L has a fairly bad oil leak on the left side where the shifter shaft enters the engine case. You have to take off the front chain sprocket cover to see it. In a rare poor choice by Ma Kaw on these engines, there isn't a bearing on that shaft where it goes through the case. Just a seal. Mine will bleed the crankcase dry in a month just sitting.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
20 Sep 2016 15:32
#743006
daveo wrote: I read that somewhat excessive oil use was typical with 1100 engines, but don't recall what was/is considered acceptable. :S
Anybody know?
I was using about a quart every 1000 miles on my '81 KZ1000 CSR when I got it with 30 000 miles. It went to a quart every 300 miles after some serious drag strip abuse, which is when I decided to pull it apart for a re-build (plus, a 1/2" chunk of clutch fiber plate came out with the oil change after several hard launches at 8 000 and shifting at 11 000 rpm.... :evil: ). I can't say that is the bike's fault....but have to give Kawasaki a lot if credit for building "bulletproof"..... :)
(And, I have to add, it didn't go any quicker than when I was launching at 6 000 and shifting at 8 500...) :silly:
Back in 1984, a buddy that had an '82 KZ1000R (owned from new) was adding a quart every 1000 miles too (again, right from new), which is about what my current near stock '83 GPz1100 is going thru now - about 35 000 miles on it. I have a magazine test that had the '83 GPz1100 and 750 tested in the same issue, and again using a quart every 1000 miles - they use the term "glutton"....
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Sep 2016 15:48
#743010
Steel valve guides. They corrected it on the 1000's. I guess the decided it was OK on later 1100's.
