GPZ750 turbo head + KZ750E + which cams?
  • G-tron
  • G-tron's Avatar Topic Author
11 Sep 2016 12:35
#741866
Hi guys,
I can get a GPZ turbo head fairly cheap for my KZ750 motor.
Is the turbo head an upgrade or is it only the regular GPZ head? Better flow? Bigger valves?
Also, I believe the turbo cams are worse than the stock KZ cams? Is that correct?
Any modifications needed to fit head? I've also read somewhere it has a bigger combustion chamber so I'll effectively be lowering the CR by doing this. Still worth it? I'll be running a 810cc kit.
Eat, Sleep, Ride
  • Julian_Boolean
  • Julian_Boolean's Avatar
Re: Re:GPZ750 turbo head + KZ750E + which cams?
11 Sep 2016 13:11
#741871
I thought the Turbo had a lower compression ratio than the ordinary bike.
  • martin_csr
  • martin_csr's Avatar
Re: GPZ750 turbo head + KZ750E + which cams?
11 Sep 2016 13:34 - 11 Sep 2016 15:26
#741874
G-tron wrote: ... Also, I believe the turbo cams are worse than the stock KZ cams? Is that correct? ....
From the parts diagrams at Kawasaki.com or Partzilla the 750 Turbo has the same camshafts as the KZ650. I don't know what else is different from the 750E, if anything. The Turbo has the same valves as a number of the 750-4 models.
Last edit: 11 Sep 2016 15:26 by martin_csr.
The following user(s) said Thank You: G-tron
  • kawi810
  • kawi810's Avatar
11 Sep 2016 14:55
#741881
stick with the kz 750 head or gpz 750 head . use gpz 750 cams if your going with the 810 kit .
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
11 Sep 2016 21:11 - 11 Sep 2016 21:12
#741916
Can anyone post combustion chamber comparative pictures of the '83 (late) GPz750 head and the standard 82 and older 750? I never knew they were that different, but now hear one is a "bathtub" like the late 1100....
Last edit: 11 Sep 2016 21:12 by Kray-Z.
  • Kray-Z
  • Kray-Z's Avatar
11 Sep 2016 21:39
#741921
Never mind - found some...interesting, too....
  • DFIGPZ
  • DFIGPZ's Avatar
12 Sep 2016 14:49
#741974
Turbo head is a down grade from KZ750 head Gpz 750 head is what you are looking for.83-85
1984 750 Turbo
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Sep 2016 14:58
#741977
Kray-Z wrote: Never mind - found some...interesting, too....
Pics?
  • G-tron
15 Sep 2016 12:02
#742363
Thanks guys,
glad I checked in on the forum before buying. Will stick with my KZ setup until I find n/a GPZ cams.
Is porting/flowing the stock head worth the trouble at all?
Eat, Sleep, Ride
  • Nessism
  • Nessism's Avatar
15 Sep 2016 13:45
#742378
One thing to realize is that the later heads got rid of the mechanical tach drive.
  • zukdave
  • zukdave's Avatar
15 Sep 2016 15:33
#742389
Best I know is the N/A and turbo head isthe same casting they have diff. part number's because the turbo
head is drilled and taped for a temp senser. Both my N/A head's have the boss it's just not drilled.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
