- Thank you received: 58
professional dyno tune - worth it?
- Zaddict
- Enjoying my Zaddiction!
Have any of you had your bikes professionally tuned? I recently installed new jetting, a full Kerker 4 to 1 exhaust system and a high-flo filter. My bike is running better than ever, but I'm wondering if there's more power to be had. Factory Pro is close and I've heard they're pretty legendary at getting the most out of a bike. Just wondering if any of you have had your kz's professionally tuned and if it was worth the time/money.
Also, side note, what kind of gas are you using? I've been putting in 91 octane but a guy on the Zephyr Zone pointed out that 91 octane in the US (which uses the AKI measure), is higher than the 91 RON recommended by Kawasaki (91 RON = 87 AKI). Further, he suggested the bike might run worse with the higher octane gas as that would effectively retard the ignition. Wondering if there's anything to the performance angle there. Lower octane gas would be cheaper in any case...
Cheers,
Mark
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
- Thank you received: 2829
- KZB2 650
- Thank you received: 265
Maybe 8 - 10 years ago I started mixing 89 and 93 oct Approx 60/40%..... straight 89 some too .... (Amco and BP, Shell once in a while) ...... just in case..... betting it so small of a diff a dyno operator would be hard pressed to see the diff...... but if I can gain a 1/4 bike length I'll take it. :silly: ...... There is also pure gas to wonder about instead of the ethanol crap ......producing a little bit of extra energy too.
I always wanted to run the bike on a dyno but never did....... am interested on hearing more from the members. Larry C hoping you might chime in.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Bowman
- Thank you received: 36
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
- Thank you received: 2749
- Kray-Z
- I need more power Scotty....
- Thank you received: 107
With a carb bike it is very expensive unless the tuner has a lot of tuning experience with the engine and parts available to try and get the right combination....not likely with your 550.
Got no reply so I'm assuming it was a mistake so I unlocked it.
- JoHNY
- Thank you received: 6
I do the tuning myself on my Triumph. Downloaded TuneECU, plug it in and away you go. Having said that, you can fuck it up real easy and fry your ECU with not to much trouble. After 8 years of learning, got there in the end.
www.tuneecu.com/
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
- zukdave
- Thank you received: 229
Looking at a print out of the a/f curve you'll see where it's rich or lean
and will know where to add/remove fue that's the first thing the dyno tuner is gonna do.
I's say take it and have about four pull's with a print out of each for an avarage reading
then go home and look at them and tune it your self.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Kray-Z
swest wrote: How did this topic get locked?
Steve - sent you a PM on that....
