KZ400 Shift Drum not turning
  • de Courcy
  • de Courcy's Avatar Topic Author
08 Sep 2016 14:13
#741585
I'm replacing my shifter return spring and after I got the new one in, I went to check the shift lever but the shift drum seems to be seized, and it wont turn. I have attached an image of it, It has 6 pins.
I know it is supposed to move freely without the clutch basket, because there is a video of someone doing just that, with the clutch removed
I followed the manual exactly, and I removed the left case just to see if there was a problem but I came up with nothing.
I would rather not reassemble everything before I know it's working.
Does anybody have experience with this?
1978 KZ400
  • de Courcy
Re: KZ400 Shift Drum not turning
08 Sep 2016 14:16
#741586
I'm wondering if maybe the reason the spring broke is because that shift drum was seized in the first place?
1978 KZ400
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 16:05
#741597
Doubt it. Have you tried turning the countershaft while shifting?
  • de Courcy
08 Sep 2016 17:16
#741606
Yes still no luck..
1978 KZ400
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 17:29
#741608
It's going from 1st to neutral and back as it should. It won't shift up anymore unless the bike is moving.
  • de Courcy
08 Sep 2016 17:43
#741612
it's not going to first or neutral or any gear.
The shift lever budge and won't turn this shift drum. Seems like the drum is seized or something. It should move freely, no?
William
1978 KZ400
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 18:50
#741629
In your clip it moves from one position to the other.
  • de Courcy
08 Sep 2016 18:54
#741633
The two arms move but they cannot move the pins on the shift drum, the drum won't budge.
1978 KZ400
  • missionkz
  • missionkz's Avatar
09 Sep 2016 01:42
#741656
The video is not your engine, correct?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • de Courcy
09 Sep 2016 04:10
#741665
No, I found the video in another post, about replacing the shifter return spring.
My spring was also broken but when I replaced it, I noticed the shift drum stopped turning. Before I opened the bike up, it would shift, just not well.
So I am very confused.
The shift drum does not budge and the clutch cable has no tension even after adjusting it multiple times, correctly with the manual. :(
1978 KZ400
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2016 06:00
#741675
Is the detent ball and spring on top of the case?
teve
  • de Courcy
09 Sep 2016 15:38
#741725
I'm not sure where the detent ball and spring are, or what they look like.
I've got good tension in my clutch cable again, but the bike won't shift up or down. Maybe it's in 3rd gear?
Does the bike have to be running and in motion to shift out of 3rd gear? Trying to figure out why the shift drum isn't turning.
1978 KZ400
