Gpz oil pump vs kz
- MadShad
Gpz oil pump vs kz
08 Sep 2016 11:07
So I've read that the 82 or/and 83 Gpz 1100 oil pumps are better than the older style 900 pumps.
I've not read why.
Anybody know the difference?
I've not read why.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
- Ktm181
- Man made it, so Man can fix it
Re: Gpz oil pump vs kz
26 Sep 2016 03:13
Hi Mate,
My Kz900 has one fitted. If i remember correct the shaft that drives it is larger diameter and the drive gear also has a larger hole to mount the shaft, i can remember if there was any other difference, i didnt pull the NEW Gpz one apart to see if the gears were different or not but i was told NOT. It bolts straight on so long as you use the gear that suits it, expensive though.
cheers,
Kt.
cheers,
Kt.
- zed1015
07 Oct 2016 15:47
Virtually identical, no difference in flow or pressure .
Newer ones have pressure switch on the pump body so blank it off when used in the KZ.
Only advantage is that it might have less wear due to being newer.
- Bozo
- Ride it like u stole it
08 Oct 2016 06:38 - 08 Oct 2016 06:39zed1015 wrote: Virtually identical, no difference in flow or pressure .
Agree, there is no difference apart from the pressure release valve, on the GPZ it is fitted to the oil pump and the KZ already has one on the main engine housing. I fitted the GPZ oil pump to the Z1R (GPZ was like new) and blanked off the valve hole BUT when I fitted my older Z1R oil pump to the GPZ I forgot about the valve so I'll have to drop the sump one day and exchange the pumps back,
I don't think it'll make much difference as the roller bearings will never allow over pressure when hot.
Last edit: 08 Oct 2016 06:39 by Bozo. Reason: spelling
