Top end oiling problem, how to troubleshoot.
  • Nerdy
  • Nerdy's Avatar
Re: Top end oiling problem, how to troubleshoot.
07 Sep 2016 14:28
#741458
MadShad wrote:
baldy110 wrote: What kind of oil are you using?
15-40 rotella.
Regardless of the pictures, my question is what should my oil flow troubleshooting process be if I suspect the top end being oil starved.
Particularly on the right side
Do you let the bike idle while it's on the sidestand? That can contribute to oil starvation on the right side.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: MadShad
  • MadShad
  • MadShad's Avatar Topic Author
07 Sep 2016 14:33
#741459
I have no center stand so while the bike is warming up with the choke on for a minute or so it's on the kickstand.
Other than that, no.
But that does make sense
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • missionkz
  • missionkz's Avatar
07 Sep 2016 15:24
#741469
I had a somewhat similar looking thing like this and a couple lobes galling.
Since the shims looked the same and smeared, I got rid of them and replaced them with new ones and a good set of used cams.
No problems now checking again after 1100 miles.
I am 80%~90% sure it was cheap crappy aftermarket sims rather then no oil.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Nerdy
  • Nerdy's Avatar
07 Sep 2016 15:37
#741471
MadShad wrote: I have no center stand so while the bike is warming up with the choke on for a minute or so it's on the kickstand.
A followup, then. :-)
When you start the bike, are you sitting on it (so it's vertical) or is it on the sidestand?
I ask because when you park it the oil will drain away from the highest points. If you start it on the sidestand those points - which have little to no oil - will be the last to get oil because it is then heading uphill (so to speak). You could be getting a lot of wear in that minute when the choke is on: elevated RPMs and oil starvation are a bad combo. :-(
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • MadShad
07 Sep 2016 15:49
#741472
I replaced some shims with ones from z1 ent.
No idea if they are oem.
The bike IS on it's kickstand while warming up, as I stated.
Here's what I'm getting at the head, the flow was the same on all 4.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Sep 2016 16:31
#741473
Looks good to me. I have two gauges. One at the test port and one on my dash. The one on the dash takes a few seconds to climb.
  • Nerdy
  • Nerdy's Avatar
08 Sep 2016 10:06
#741544
MadShad wrote: The bike IS on it's kickstand while warming up, as I stated.
Yes, I saw that. But 'starting' and 'warming up' are two different things: I was talking about the actual choke-and-starter part of the process. I prefer to do that while sitting on the bike, hence the question. Maybe you start the bike from the saddle and then put it on the sidestand; how would I know without asking?
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • MadShad
08 Sep 2016 10:45
#741548
Sorry, yes I sit on the bike when i start it.
Learned that lesson as a kid when I dumped my first street motorcycle by starting in gear on the stand.
Once started i put it on the stand while I gear up.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 11:12 - 08 Sep 2016 17:00
#741555
Being the strainer is at the bottom of the sump, it shouldn't starve for oil.
Last edit: 08 Sep 2016 17:00 by SWest.
  • Nerdy
  • Nerdy's Avatar
08 Sep 2016 16:57 - 08 Sep 2016 16:57
#741598
MadShad wrote: Sorry, yes I sit on the bike when i start it.
No worries. And ouch to the dumping. I hope no one saw that. :-)
If this is the source of your wear, you may want to gear up and then start up so the bike is vertical the whole time.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
Last edit: 08 Sep 2016 16:57 by Nerdy.
  • bluezbike
  • bluezbike's Avatar
13 Sep 2016 22:46
#742159
MadShad wrote: I'm using an oil cooler with lager I.D. lines and fittings than what the gpz 1100 used stock.
I'd think that was big enough, maybe its not.
My pressure gauge should be here tomorrow.
These motors normally run on very low oil pressure (with higher capacity) so I wonder if by installing larger oil lines you may have inadvertantly created an oil starvation problem.
79 KZ 1000 LTD
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
13 Sep 2016 23:21 - 13 Sep 2016 23:24
#742160
I think you might have encountered a combination of bad circumstances.....
1. Check oil flow? - pull the right side exhaust cam bearing cap and have a look at the bearings - if they look good, then you are probably flowing enough oil to the right side.
2. Your aftermarket shims (I'm pretty sure Z1 Ent. sells quality, but A/M shims - they might be hard as OEM, but not as smoothly finished / polished - new OEM's are ground like mirrors on my Hondas) might have contributed to lobe wear, when combined with...
3. Starting and / or warming the bike while it is tilted over too far on the side stand (how far does it lean?), and just a little wear on the cam lobes is the beginning of the end...once the hard face starts to wear, it accelerates very quickly...there is no cure after that. The lobes do not get direct oil supplied to them - they depend on the pools of oil left from leaking out of the cam bearings and past the lifters.
4. If you are intent on gauging the oil pressure to the cams, drill and tap into one of the right side head oil galleries for a fitting so you can temporarily install a pressure gauge. Plug the gallery when you are done.
Last edit: 13 Sep 2016 23:24 by Kray-Z.
