82 kz550 ltd
- greene.1993
82 kz550 ltd
04 Sep 2016 16:06
Hey guys I have a 82 kz550 ltd all stock. I have an issue on the highway when I get up to speed at 65 mph, if I accelerate too much I hear the bike sputtering. Any ideas what it is and how to fix it.
Thanks
Thanks
Re: 82 kz550 ltd
04 Sep 2016 16:12
Do a plug chop at that speed when it does it.
- greene.1993
Re: 82 kz550 ltd
04 Sep 2016 16:48
Go out to a empty stretch of road, get up to that speed and make it do that. Pull in the clutch at the same time killing the engine with the switch. Coast to a stop and check a plug.That will tell you what is happening.
- Kray-Z
- I need more power Scotty....
Re: 82 kz550 ltd
04 Sep 2016 23:35swest wrote: Go out to a empty stretch of road, get up to that speed and make it do that. Pull in the clutch at the same time killing the engine with the switch. Coast to a stop and check a plug.That will tell you what is happening.
Greene 1993 - download a picture guide from the 'net - in color - on how to diagnose spark plugs. That will be a good guide for what is happening. Here is one I found that is pretty good for diagnostics forcarb tuning....
Attachment spark-.pdf not found
- Kray-Z
Re: 82 kz550 ltd
04 Sep 2016 23:53 - 05 Sep 2016 00:02
To clarify the "plug chop".... for your specific application:
Take the fully warmed up bike out on an open stretch of road (no traffic or other dangers). In as high a gear as possible (top gear is best), get to the engine speed and load you are starting to have trouble at, and accelerate with the steady throttle setting that causes the worst performance. After 4 or more seconds, quickly pull in the clutch and kill the engine at the same exact time. Coast to a stop with the clutch in (o.k. to use the brakes, just don't let the engine turn over), and immediately pull one (or more) of the plugs and compare them to the color chart. Determine what problem you are having by the condition of the spark plug(s) and compensate accordingly. Most likely your bike is experiencing a fuel (carburetor) issue.
The "classic" plug chop you might read about elsewhere is to go out on an open road, uphill, in fourth or higher gear at sixty or more mph and open the throttle fully for 5 to ten seconds before pulling in the clutch + shutting the engine off. This is quite dangerous on a high powered bike, as you could be exceeding 80 - 90 mph, and it only tells you about the air - fuel mixture at wide open throttle - in other words mostly the main jet size. Steve's (swest) recommended way is much better to diagnose the problem, and safer, too....
Last edit: 05 Sep 2016 00:02 by Kray-Z.
- rrsmsw9999
Re: 82 kz550 ltd
05 Sep 2016 06:23 - 05 Sep 2016 06:25
I would say no need for high gear and high speed to plug chop. The throttle needs to be in be in wide open position when you "chop" . This could be done in any gear. I would sugest 2nd and chop when it is at 7000-8000 rpm. Be sure to hit the kill switch when the throttle is open or u won't have an assessment at WOT. This will tell u some about WOT or main jet selection. then if the plugs are white u r lean, black or wet rich and brown just right. If u have a cruise control you can pin the throttle openin fifth at 50 for a few seconds before it gets to 100. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 05 Sep 2016 06:25 by rrsmsw9999.
Re: 82 kz550 ltd
05 Sep 2016 06:28
I suspect the plug/s will be wet.
- loudhvx
Re: 82 kz550 ltd
05 Sep 2016 11:22 - 05 Sep 2016 11:23
I agree, no need to do a plug chop yet. First, just take the plugs out and see if one is different from the others.
How about some basic bike info?
Compression test results?
Valves adjusted recently?
Ignition timing checked (and advancer inspected/cleaned/lubed)?
Coils good condition?
Stock jetting confirmed?
Airbox is stock.
Stock exhaust.
Do you have the manuals?
You can get several manuals from the links in my signature, and read the valve train warning before removing the valve cover.
Airbox is stock.
Stock exhaust.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 05 Sep 2016 11:23 by loudhvx.
