Dyno cover leak
- missionkz
Dyno cover leak
03 Sep 2016 18:01
Where are you people cutting the three Dyno wires in order to slip the new grommet on?
Behind the counter shaft sprocket cover or?
I no longer can take this three or four drip every time I shut down for an hour or the end of the day.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Re: Dyno cover leak
03 Sep 2016 18:20
I did it inside the dyno cover. Next time it will be under the sprocket cover. I used crazy glue to seal the woven sheaths covering the wires so they wouldn't wick. I then filled the channel where the wires came out of the cover. I got tired of oil on my FOOT.
