Possible causes of wet fouling spark plugs
- someonewakeuphicks
22 Aug 2016 09:25
Since I've owned my bike, I've had a trouble with wet fouling spark plugs that reek of gasoline. I've never had to troubleshoot an issue like this before and was wondering if anyone had some pointers.
I took it for a rip over the weekend and it would run fine but stall out when I got to a stop light unless I kept the idle up around 1500 rpm
I've already gone to a K&N air filter and BR7ES in hopes of getting more air and a hotter spark. I'm also still running points which look clean
Always remember to keep the rubber side down!
Bikes
'78 KZ650c2 - Current love affair
'04 Fz6 - Current daily rider (until the KZ is finished)
'82 XJ550 Seca - RIP Little Red
Bikes
Re: Possible causes of wet fouling spark plugs
22 Aug 2016 10:54
Tight valves, weak coils, timing issues, jets too large, float level too high.
22 Aug 2016 11:43
Try a set of ND W22ES-U spark plugs. They made a difference in my KZ650-C1. Ed
- KZ650 Cafe
22 Aug 2016 12:49
i would imagine by what i read on here if you still have points start with resetting them no matter how clean they look. i have a 77 kz650 with a dynatek swap and i was getting spark before i hooked up the starter no im getting nothing.... lol but im sure your problem is your points, even though i hear alot of crap about ngk plugs... but idk i use the stock champions plugs.
Sam
22 Aug 2016 13:06KZ650 Cafe wrote: ..... i use the stock champions plugs.
Champion plugs didn't come stock on my 1977 KZ650. Do you live outside the US? Ed
- KZ650 Cafe
23 Aug 2016 07:39
lol i live in texas, and i should have stock equivalant . . they are basically the same as B7es plugs. 7 temprature range and so on
Sam
- KZ650 Cafe
23 Aug 2016 07:43
reset the points and stick with the stock filter until you get a jet kit. if the bike has sat for any length of time no matter how clean the points look check them, i recommend going with dynatek dyna s system for the bike from dennis kirk. set it and forget it i never have any starting issues now that ive converted, and sometimes i run a little hotter plug just for a little more power if i decide to run av gas.
Sam
- KZB2 650
23 Aug 2016 08:17
Maybe check the things Steve said and are your Champions 4s (I personally like em and have used them).... maybe stay away from the resistor NGK's ..... av gas sounds good but if you have a stock comp motor your probably loosing a "little" power instead of gaining over 89 oct...... and I love my Dyna S too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- bountyhunter
24 Aug 2016 00:02 - 24 Aug 2016 00:04sounds like flooding from carburetor floats not cutting off fuel at correct level.someonewakeuphicks wrote: Since I've owned my bike, I've had a trouble with wet fouling spark plugs that reek of gasoline. I've never had to troubleshoot an issue like this before and was wondering if anyone had some pointers.
Have no idea how points or plugs can cause gas flooding...... :huh:
Last edit: 24 Aug 2016 00:04 by bountyhunter.
