Stator
  • goldylox
  • goldylox's Avatar Topic Author
Stator
11 Aug 2016 08:48
#738262
About five months ago stator look new just looked at it lastnight and it is in pieces and burnt up do anyone knw why is it maybe lavk of oil
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Stator
11 Aug 2016 09:09
#738264
Was it new about five months ago, or just looked that way?
If Made in China, you have my answer. :(
1982 KZ1100-A2/1170 sleeper 😀
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • TexasKZ
  • TexasKZ's Avatar
Re: Stator
11 Aug 2016 11:04
#738274
Do you ever check the oil level? I seriously doubt low oil level caused this, but it can cause catastrophic failures elsewhere.
  • Nessism
  • Nessism's Avatar
Re: Stator
11 Aug 2016 11:43 - 12 Aug 2016 07:46
#738283
The generator uses permanent magnets to make power and all the excessive power the generator makes that is not consumed by the bike will be shunted back to the stator by the R/R. The stator runs hot under normal conditions and when current is shunted back to the unit it runs hotter still, which can burn it up.
Best thing you can do for your charging system is make sure you have good electrical contacts throughout, and get a SERIES R/R. This type of R/R does not return excessive current to the stator, thus it helps protect it from overheating. Shindengen makes the SH775 for both OEM and aftermarket usage. Triumph speced the SH775 in a repair kit because their bikes were burning up too many stators. Best of all is that you can get one for cheaper than most junky made in China shunting R/R's. It's a win win situation.
Last edit: 12 Aug 2016 07:46 by Nessism.
The following user(s) said Thank You: GatlinM
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Stator
11 Aug 2016 12:01
#738287
+1 Ed
Watch out for imitation-fakes Made in Chihina! If shopping on ebay, be sure to buy the regulator made by Shindengen with the model printed on the end of the unit. The Chihina units are virtually identical to look at, so watch out!
Disclaimer: If Country of manufacture is irrelevant to you, please disregard the above comment which may not represent any opinions other than mine.
  • goldylox
Re: Stator
11 Aug 2016 14:37
#738303
Wats a r/r
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • goldylox
Re: Stator
11 Aug 2016 14:43
#738306
No it wasnt new it just looked a little better than wat it does now but it did have corosion around wires i guess it could just be time for a new one
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Stator
11 Aug 2016 14:59
#738309
What bike is it? Can you post a picture or two? :blink:
  • loudhvx
  • loudhvx's Avatar
Re: Stator
11 Aug 2016 15:50 - 11 Aug 2016 15:54
#738314
The stator does not need to be bathed in oil. The big motors (and twins) have oil in that area for the starter clutch, and some gets on the stator. The smaller fours are completely dry in there.
My buddy, who works on a lot of Hondas, is finding cheap knockoff stators from China showing up on some of the bikes he getting in. They burn up fast. We were just talking about this today while troubleshooting a CB750 charge system. (This one had a bad regulator, also from China.)
Last edit: 11 Aug 2016 15:54 by loudhvx.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Stator
11 Aug 2016 16:09
#738316
Can't help work on something you can't see. :S
