Manley valves
  • TerryK
  • TerryK's Avatar Topic Author
Manley valves
05 Aug 2016 11:09
#737551
Besides APE, anyone know a good alternative source for Manley valves? APE is out of stock and I need a 30mm Manley stainless exhaust valve for KZ9900/1000
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
Re: Manley valves
05 Aug 2016 13:48
#737566
Try Joe @ Pit Stop Performance.
Next bet would be the other re-sellers - Dynoman, Z1 Ent, Schnitz, Star Racing. Any of them might still have stock available.
How quick does your 77 go - BTW?
  • PaintWorkz
  • PaintWorkz's Avatar
Re: Manley valves
05 Aug 2016 13:54
#737568
Kibbelwhite makes stainless valves
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • TerryK
Re: Manley valves
05 Aug 2016 16:17 - 05 Aug 2016 16:20
#737578
Tried Ape, Schnitz, Z1, Star, Dynonan. no luck. I'll try pit stop thanks.
Bike should run 11.0 with this head installed.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 05 Aug 2016 16:20 by TerryK.
  • TerryK
Re: Manley valves
05 Aug 2016 16:19
#737579
The head I'm using has all Manley valves. I don't want one different valve.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Kray-Z
  • Kray-Z's Avatar
Re: Manley valves
05 Aug 2016 18:07
#737593
TerryK wrote: Bike should run 11.0 with this head installed.
Awesome!
I was hoping for 11.5's @ 120 with my new street beater KZ/GPz (Wiseco 1170, etc...), but it doesn't look like I'll make any passes at all this year...maybe next season, I hope.
  • TerryK
Re: Manley valves
06 Aug 2016 07:15
#737625
Awesome!
I would think it would run better than that.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • missionkz
  • missionkz's Avatar
Re: Manley valves
06 Aug 2016 08:51
#737631
TerryK wrote:
Awesome!
I agree!
I'm no semi-pro drag racer but my nearly stock 77' KZ1000a would run 1320's at just at or under 12.00 seconds fairly consistently.
I even had one stellar ride with an 11.67 et.
My only mods were:
A 14 tooth counter shaft sprocket and 35 tooth rear wheel sprocket, Denco headers, properly jetted carbs and over the counter Dyna III electronic ignition system.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • TerryK
Re: Manley valves
06 Aug 2016 09:41
#737633
B)
missionkz wrote:
TerryK wrote:
Awesome!
I agree!
My only mods were:
With a Dyna-s, Accel coils, weiseco header, 29 mikuni flat slides my 1075 ran 12.30s @ 108 all day long, which is about 3.5 tenths slower than it should. Stock cams are a huge limiting factor.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • missionkz
Re: Manley valves
06 Aug 2016 10:40
#737637
Mid to high 12.0's was quite average ETs for a these stock'ish KZ1000's and non semi/pro riders in Detroit, MI.
My advantage was, back then, I was screwing around with riding a semi-drag bike Kaw H2 750, so I learned how to really get a good launch on a motorcycle and I weighed in at around 132lbs dressed and in leathers with helmet!!
I've only taken my 77' KZ1000a to drag strip three times. It was my main transportation ride!
But I think with a few weeks practice on my slightly modded KZ and a better rear tire, I could've have ridden it consistently in the high 11.70's back then.
Your modded bike should go faster then mine ever did.
Bruce
1977 KZ1000A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Manley valves
06 Aug 2016 15:30
#737652
missionkz wrote:
TerryK wrote:
Awesome!
I agree!
My only mods were:
Just ordered a new 15T sprocket. Dog off the line with the 16 and my 130 tire. :dry: Great on the HWY though. :whistle:
  • missionkz
Re: Manley valves
06 Aug 2016 18:47
#737667
swest wrote:
missionkz wrote:
TerryK wrote:
Awesome!
I agree!
My only mods were:
Hmmmm..... yeah I'm still on the fence about trying that 16/35 combo Steve.
The 15/35 is just a pinch lower then the stock 15/32.... I'm not sure I can feel the difference.
I certainly can feel the 14/35!!
Bruce
1977 KZ1000A1
