The kz don't start anymore
  • Fox
  • Fox's Avatar Topic Author
30 Jul 2016 07:26 - 30 Jul 2016 07:28
#736686
Hello all,
The kz don't start.
I check the spark plugs and alls have a fire.
I check the cabs fuel level with clear tubes method.
I check the battery level.
I check the air filter.
I check the fuel quality.
Petcok on, neutral position, run button on.
I try the kickstarter.
The motorccyle is in a good condition. was starting like a charm 1 year ago. But was more an more long to start the first start since next month. Then when she was running, it was not difficult to restart.
I have no more ideas actually...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Last edit: 30 Jul 2016 07:28 by Fox.
  • Nessism
  • Nessism's Avatar
Re: The kz don't start anymore
30 Jul 2016 07:30
#736687
When was the last time you adjusted the valves.
If the bike has sat for more than 3 months the carbs could be gunked up too.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jul 2016 07:30
#736688
Valve adjustment?
The following user(s) said Thank You: Fox
  • Fox
30 Jul 2016 07:39
#736691
Carbs just cleaned.
Valves ? I didn't check anything like that...
Do you have a tuto?
Regards
fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jul 2016 07:42
#736692
What bike? Do you have a manual? Pics?
  • Fox
30 Jul 2016 07:56
#736695
1978 KZ1000-B2 LTD
I have the manual of the 1977 KZ1000-B1 LTD
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • martin_csr
  • martin_csr's Avatar
30 Jul 2016 08:09
#736696
How old is the battery & did you keep it charged? I would charge it with a motorcycle battery charger & make sure it is good. you should test it --- don't assume it is good. After charging, it should be at least 12.6 VDC, but a good battery will usually be higher. A simple load test is to charge the battery, then turn on the headlight high beam (engine off). A good battery will drop from 12.6+ VDC to about 12.2. If it drops below that, the battery may need replacing. If it drops below 11 VDC, the battery is probably shot.
The following user(s) said Thank You: Patton, Fox
  • Nessism
  • Nessism's Avatar
30 Jul 2016 08:28
#736699
Fox wrote: 1978 KZ1000-B2 LTD
You have a 38 year old motorcycle. How about cracking that manual and doing some maintenance? There is a maintenance table in the manual which tells you what should be done and how often. In addition your bike is sure to need a deeper level of maintenance due to neglect. For example, failing to adjust the valves will damage them as well as the cylinder head. if that's the case you need to recondition the head which is an even bigger maintenance task.
  • Fox
30 Jul 2016 08:45
#736703
Hello,
the battery have 1 year. I keep it charged. Btw it's a RONA battery... not something strong...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Ltbones
  • Ltbones's Avatar
30 Jul 2016 09:00
#736704
Try checking the switch on your clutch as I have just suffer this with mine. Am new here but own a KZ1100 1982
If not that look at the second fuse they tend to fur with corrosion. Hope it helps nail down some things...
Regards
Lt
  • Fox
30 Jul 2016 09:23
#736706
I'm at work actually but i will check that this morning.
Every idea is welcome :)
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Fox
30 Jul 2016 12:09
#736719
Yep, i think it's time to open the head and check a bit.
I the same time i can see a small, very small leak from his gasket. I will see what's happen there ...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
