Gunson Colortune Y/N?
- wrenchmonkey
10 Jul 2016 08:21
I'm considering buying this tool and was curious what others here that have it, think of it:
I wanted to make this a voting poll but couldn't get it to work. :blush:
- Did you buy it - (or it is a gift)
Y/N:
- Do you use it -
Y/N:
- Do you recommend it -
Y/N:
Y/N:
- Do you use it -
Y/N:
Y/N:
Re: Gunson Colortune Y/N?
10 Jul 2016 08:24
It will get you in the ball park but you'll still have to dial it in. I had mine too lean and adjusted accordingly.
- daveo
10 Jul 2016 08:56swest wrote: It will get you in the ball park but you'll still have to dial it in. I had mine too lean and adjusted accordingly.
Steve, did you dial it in using the Colortune to obtain the correct mixture?
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: wrenchmonkey
10 Jul 2016 09:34 - 10 Jul 2016 09:35
Keep your bike stock and you don't need no Colortune! :lol:
Last edit: 10 Jul 2016 09:35 by Nessism.
The following user(s) said Thank You: 650ed, wrenchmonkey
- ThatGPzGuy
10 Jul 2016 11:32
I use one and recommend it. so Y...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
10 Jul 2016 12:37daveo wrote:swest wrote: It will get you in the ball park but you'll still have to dial it in. I had mine too lean and adjusted accordingly.
You can use it to get close if you're rejetting. If not, you'll set the mixture screws per instructions then bring up the revs to about 2500 or where you hear a miss and dial it out with the screws in or out.
- Mykzisbroke
- undiablo
11 Jul 2016 05:24
I have one.
It is a good tool for idle mixture adjustment. I recommend it.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- KZJOE900
- Administrator
Super Users
11 Jul 2016 06:53
I wish I had four instead of just one. But they are a bit pricey. Pain in the neck handling it once hot when transferring to the successive cylinders after doing the first cylinder. But it works. I frequent another site where a member hosts an annual carburetor clinic in upstate NY. They use four units and are able to tune (colrtune and vacuum sync) about 20 bikes in a day. Must be nice to have such convenience. I liked mine when I used it, but haven't used in probably 2 or three years.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
11 Jul 2016 06:57
I've used mine twice and there it sits in the box. :dry:
- apbling
11 Jul 2016 06:57
I have one but it doesn't work for me. Tried it on
A 750 (4cyl) and a 550. It won't ignite unless
I richer it way way up. It's like it's not need enough
In the cylinder. I contacted them and they sent
Me a new one. Same result.
- wrenchmonkey
11 Jul 2016 11:13
I was curious if anyone would mention that - problems with it not being long reach into the combustion chamber... i have been looking at them and thinking it would be a useful addition to the tool box but saw how short they are on the threaded side and feared it may be inaccurate as a result.
Thanks to all that replied with your experiences!
