cut out at 6000rpm
  • blink543
  • blink543's Avatar Topic Author
cut out at 6000rpm
04 Jul 2016 20:10
#733888
I've been getting engine cut out at around 6000 rpm. petcock is working, rode with tank cap open, rode on prime, same issue, this is all the sudden. even in 5th gear doing 25 mph I'll open throttle all the way and I get sputtering. wtf? I rigged my bike with a relay so the coils get direct 12v because before they were getting 9. so what do i do?
Adam james
  • blink543
Re: cut out at 6000rpm
05 Jul 2016 01:32
#733917
when I took off the manifold vacuum port nipple it had gas in it. In the nipple cover.
Adam james
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • baldy110
  • baldy110's Avatar
05 Jul 2016 08:45
#733962
Was the bike running ok then start this or has it always done this, also did you recently do work to it?
  • loudhvx
  • loudhvx's Avatar
05 Jul 2016 09:37
#733969
The relay can be your problem if it is mounted in a way where it can vibrate. Try soft mounting it temporarily.
It can also be your advancer is stuck. That will limit the RPMs.
Or it could be that whatever problem you were having that caused you to install the relay is still a problem... bad coils, bad igniter/points, etc.
  • blink543
05 Jul 2016 10:26
#733970
loudhvx wrote: The relay can be your problem if it is mounted in a way where it can vibrate. Try soft mounting it temporarily.
so I found out running it without air filter fixed it. it's a cheaper paper filter. I'm going to get k&n now. btw I have an airbox. filter didn't look dirty. i guess the restrict easier.
Adam james
