Factory 4>1 for an 82 GPz750?
- GKBO
- Saving old"dead" bikes
Re: Factory 4>1 for an 82 GPz750?
05 Jul 2016 19:04Woooo hoooo....finally got the baffle out of the V&H,was thinking of getting a new V&H baffle but making a mechanical baffle has taken over in my mind.Makes this thread kind of redundant but a thanks to all for your input.GKBO wrote:That would be fine IF I had a 550 to fit it onloudhvx wrote: The inline 4 Kz400J is almost identical to the Kz550's, but with smaller displacement. If it fits a Kz400-4, it should also fit a Kz550.
The seller realized this wasn't a system when he looked at it.It was in a bunch of parts he got in 5 boxs that are supposed to be for an 82 R1. He's going to check spacing ,port sizing and frame clearance to see if it will fit.Gave me an tip on how I might get the broken baffle out of the V&H that came with the bike to.so I MAY be able to use that.
- Tyrell Corp
07 Jul 2016 04:48
That header isn't Kawasaki, looks more like Sebring with it's unusual four in a line collector arrangement.
Kawasaki did a 4-1 kerker on the z1000R R1 ELR, also it was available as a dealer option for a few of the kz range, they were badged 'kerker by kawasaki'.
- GKBO
07 Jul 2016 05:18That's a new one on me,don't remember Sebring exhausts.Was going to tell the seller I'd give it a pass.Now I'm thinking I should get it just because of the that's cool.All provided it will actualy fit my GPz of courseTyrell Corp wrote: That header isn't Kawasaki, looks more like Sebring with it's unusual four in a line collector arrangement.
07 Jul 2016 05:40
I've never heard of Sebring exhaust either. That header looks like some sort of OEM type to me. The collector is stamped steel, so that means someone spent money on a tool which isn't cheap. Aftermarket guys don't typically do this. The angle of the tubes makes me think this header is for some bike with an engine that cants forward in the frame. The engine in our KZ's sits more upright.
- GKBO
10 Jul 2016 21:06Yeah looking at it again it does look like it's more for a angled cylinder bike,it has an OEM look as well.Decided not to worry about it as I no longer really need it anyway.On a twit note I may have thrown out the end cap of the baffle I had.Will see if my local dealer can get a new V&H baffle.It's that or try making my own end cap. :SNessism wrote: I've never heard of Sebring exhaust either. That header looks like some sort of OEM type to me. The collector is stamped steel, so that means someone spent money on a tool which isn't cheap. Aftermarket guys don't typically do this. The angle of the tubes makes me think this header is for some bike with an engine that cants forward in the frame. The engine in our KZ's sits more upright.
