Gear linkage loose
  • JoHNY
  • JoHNY's Avatar Topic Author
Gear linkage loose
02 Jul 2016 15:34
#733631
Over the years the lever is loose on the stud lever pivot. I don't want to buy a whole new lever, anyone any ideas what kind of internal sleeve to use?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
  • davido
  • davido's Avatar
Re: Gear linkage loose
03 Jul 2016 00:25
#733682
I had this on an old Honda once. I filed the slot open a bit wider,so that when the pinch bolt is tightened down,it has a better grip. More pinch.
Its still working today.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Nessism
  • Nessism's Avatar
03 Jul 2016 05:34
#733689
If you replace the stud that will remove some of the slop. As for what type of sleeve, bronze is commonly used for sleeves. Sleeving that shifter would be difficult unless you are a machinist and have access to the proper equipment. A reamer of the proper size would be needed for one thing.
  • JoHNY
03 Jul 2016 13:00 - 03 Jul 2016 13:01
#733712
I've used a thin gauge slice of aluminium which has worked to an extent, still a bit loose. I'm sure i can get a suitable thin piece of bronze
Last edit: 03 Jul 2016 13:01 by JoHNY.
  • davido
  • davido's Avatar
03 Jul 2016 13:23
#733716
davido wrote: I had this on an old Honda once. I filed the slot open a bit wider,so that when the pinch bolt is tightened down,it has a better grip. More pinch.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Nessism
  • Nessism's Avatar
03 Jul 2016 15:44 - 03 Jul 2016 15:45
#733725
In regard to davido's comment, I don't see how that would apply in the case of this shift lever.
The lever has a bore that slips over a stud mounted to the case. The lever is held to the stud with a C-clip. There is nothing to "pinch".
Regarding sliding an aluminum shim inside the lever to tighten up the fit, all I can say is good luck. There are various ways to fix broken bike parts, but that sounds like the wrong way.
Last edit: 03 Jul 2016 15:45 by Nessism.
  • wrenchmonkey
  • wrenchmonkey's Avatar
03 Jul 2016 15:53
#733727
It sounds like any solution would be a stop-gap or bandage until a real option could be purchased - new parts to replace the worn ones.
Are replacement parts available?
Could the receiver & shaft be cross drilled for a spring pin of sorts?
Just another bandage but may buy some time until replacements are acquired...
  • TexasKZ
  • TexasKZ's Avatar
03 Jul 2016 18:04
#733733
A bronze bushing would be a good choice , but it will require careful machining of the shifter and the shaft to insure a good fit. A small zerk for grade would be good for the long run. The sexiest solution would be needle bearings. A member of the ZRXOA does a bearing conversion for the ZRX. Maybe he would be willing to do a KZ, too. If you are interested, I can chase down his contact info when I get home tomorrow night.
  • JoHNY
03 Jul 2016 23:29 - 03 Jul 2016 23:29
#733750
Cheers Texas but I'm in the UK. I was looking at a replacement lever link but you can't seem to get a new one. There are a few used ones on ebay but these look pretty worn. A bearing solution would be ideal. Another solution would be to do away with linkage and use a normal shift lever but that would take the end of the lever too far forward. I've got big feet but not that big.
Last edit: 03 Jul 2016 23:29 by JoHNY.
  • Nessism
  • Nessism's Avatar
04 Jul 2016 06:42
#733777
Thinking about this a little more and I think the easiest thing to do would be to install a sleeve around the old stud. A machinist could easily turn down the old stud a little in a lathe and then press a bushing onto it. If you want a truly righteous fit I'd ream out the ID of the shifter bore with a reamer to the next larger size and size the bushing so you have a nice tight fit.
  • JoHNY
05 Jul 2016 01:10
#733915
Great idea, friend of mine has a lathe and could do this for me, cheers buddy :)
  • davido
  • davido's Avatar
05 Jul 2016 01:50
#733918
Nessism wrote: In regard to davido's comment, I don't see how that would apply in the case of this shift lever.
My mistake. A different system to the one I was thinking (writing) about.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
