Removed exhaust to clean now idle is rough
  • markitzero
  • markitzero's Avatar Topic Author
02 Jul 2016 10:54
#733609
Hey,
This is my first post, and just want everybody to know this site has been a god send.
I removed my stock exhaust from my 1978 KZ400B to clean almost 40 years of baked on chain lube and now the bike does not idle as smooth. The tach will fluctuate between 1200rpm to about 700rpm and occasionally dies. I did notice when removing the exhaust pipe holder and split keeper weren't tight, and the gasket looked a little worn out. When I reinstalled i tightened everything, so maybe this is my issue? Any advice would be greatly appreciated.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Removed exhaust to clean now idle is rough
02 Jul 2016 11:14
#733611
Welcome. Did you touch anything else? Pics?
  • Nessism
  • Nessism's Avatar
02 Jul 2016 11:22
#733612
I doubt removing and replacing the exhaust caused the issue.
Did you replace the pipe gaskets?
Have you vacuum synced the carbs lately?
Air filter clean?
No air leaks?
  • markitzero
02 Jul 2016 11:23
#733613
Thanks Steve! nope just the exhaust.
  • markitzero
02 Jul 2016 11:25
#733614
No i didn't replace the gaskets, the filter is brand new and just vacuumed synced the carbs
  • undiablo
  • undiablo's Avatar
04 Jul 2016 06:25
#733772
Sorry, but I don´t think you can vacuum synch the carbs if the bike can´t maintain a steady idle.
You might have an exhaust leak somewhere. change the exhaust copper crush gaskets and re-tight everything.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jul 2016 06:32
#733774
Valves and other things must be set before going to the carbs.
  • wrenchmonkey
  • wrenchmonkey's Avatar
04 Jul 2016 08:59
#733793
Is it possible that when you were removing the exhaust, you may have snagged the ignition wires below the ignition cover and perhaps loosened one or more wires from their respective connectors?
Can't think of anything else that could be related to just removing the exhaust for cleaning.
I'd re-inspect every wire connection (even under the seat or not obvious areas) as a sanity check so you don't end up chasing a ghost in the machine.
  • markitzero
04 Jul 2016 10:06
#733798
The carbs had been cleaned and synced before the exhaust was removed and idled at the factory specified 1100-1200 rpm range. I have gaskets on order (back orders until July 11). I'll check the wiring in the mean time. But I'm thinking it's the exhaust gaskets as they should be a crushed fit. Thanks for all the responses, I'll keep you updated as I progress.
  • markitzero
24 Jul 2016 13:49
#736067
So Finally received the crush gaskets for the exhaust and installed with some cooper gasket seal and still idles rough. My next move will be looking at the carb boots (holders) as they are pretty knackered and thinking i may have removed the carbs one too many times.
Any one have any experience with these after market carb boots:
CARBURETOR INTAKE BOOT - (FITS: '78 & '79 KZ400)
  • martin_csr
  • martin_csr's Avatar
24 Jul 2016 17:13
#736081
By markitzero: Any one have any experience with these after market carb boots:
The description says OE. original equipment.
  • markitzero
24 Jul 2016 21:12
#736127
Yes you are correct, I was under the impression Kawasaki didn't make this product anymore.
