White Corrosion in Exhaust Port,also Starter issue
  • Kowitz
  • Kowitz's Avatar Topic Author
25 Jun 2016 10:40 - 25 Jun 2016 10:41
#732769
Hey everyone,
I recently picked up a 1981 KZ550 LTD, and have done some work to it, and got it running great. Well, it was missing a few pieces, so I was able to track down a second 1981 KZ550 LTD, that I was planning on using for parts only(It even had a Vance and Hines 4-1 on it!)
Anyway, I figured, the 2nd bike is pretty complete and it has a clean title, it just needs a lot of love. So I might as well try to get it running too, and if I can, maybe make it my winter project, and tear it all the way down.
So, before I took anything off of it, I hooked up my battery from my running bike, and wanted to see if it would fire. Well, after pushing the starter button, I only hear one click, like the starter is seized or something, and also the positive side battery cable got super hot. So perhaps a bad ground? Just looking for ideas on where to start.
After that, I went to pull the V&H exhaust off, to put on my good bike(since the previous owner had chopped off the stock mufflers), and this is what I found. Again this is on my "parts" bike, that I hope to get running also. This huge amount of white corrosion around the exhaust port, and even down on the valves it looks like, on all 4 cylinders. Do you think the motor is shot?
Just looking for a few ideas on where to start with the starter issue, and if I should even waste my time on this motor. Thanks everyone!
-Brenton
1981 KZ550c
Last edit: 25 Jun 2016 10:41 by Kowitz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: White Corrosion in Exhaust Port,also Starter issue
25 Jun 2016 10:55
#732771
Lots of water got in there. Pull the head and see what you got.
  • Nessism
  • Nessism's Avatar
25 Jun 2016 15:01 - 25 Jun 2016 15:02
#732788
Agree, looks like water in the engine. You may want to try turning the engine over with a wrench on the RH end of the crank (rotate clockwise as viewing from the RH side)
BTW, most likely the starter is fine but the engine is seized.
Last edit: 25 Jun 2016 15:02 by Nessism.
