Leaking oil from head gasket
  • flhwesty
  • flhwesty's Avatar Topic Author
24 Jun 2016 11:45
#732673
I have a 1983 GPz750. It's rough. I paid almost nothing for it and have rode it to work for 1.5 years (not in January & February). The head gasket has been leaking oil. Now it is LEAKING oil. Can I re-torque the head as a possible fix. I need about a month to get my project bike fixed. I remember reading on this forum about loosening and re-torquing head bolts, but can not find the post.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • Nessism
  • Nessism's Avatar
Re: Leaking oil from head gasket
24 Jun 2016 12:45
#732682
Yes, loosen just enough to get the nut moving and then tighten. You got nothing to lose. At the same time be sure to take some extra time and adjust the valves if you haven't done it lately.
The following user(s) said Thank You: flhwesty
  • RonKZ650
  • RonKZ650's Avatar
24 Jun 2016 15:38
#732697
Probably not the gasket leaking, it's most likely those oval shape o-rings that seal oil passages. Common problem. I hate the fact the 550/650/750 used this design. Rubber gets hard and dry from age and heat and leaks start. They use 100 o-rings it seems like, so keeping from leaking over high miles is a constant battle.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jun 2016 16:06
#732699
Would Viton be better?
  • Inline88
  • Inline88's Avatar
  • Twist the wick
31 May 2020 09:51
#827006
What if you use ape head bolts and get it tightened down more. I’ve thought about trying this on my bike. Wonder if threads are bottomed our in stock nuts
82-KZ1100-A2 shaft
82-GS850g shaft
81- kz1000 Ltd 1075
  • Greybeard
  • Greybeard's Avatar
31 May 2020 12:55
#827018
RonKZ is probably right. I'm just about ready to put my 83 1100 back together after it was leaking oil everywhere.
Everywhere was 98% old O-rings.
I tried retorquing first.
It made mine leak worse.
1982 KZ1100 D-1
