Nasty engine rattle and vibration
- Tyrell Corp
Re: Nasty engine rattle and vibration
24 Jun 2016 08:53
When idling it comes and goes and if rattling on start up it goes when bike is put into gear
sounds like clutch basket rattle, they all do that. Balancing carbs and a tune up will minimise it.
slappy camchains make noise at higher rpms, in gear and in nuetral. likewise a balancer shaft issue.
- Captainkiwi
- Vrooooooooom
24 Jun 2016 09:15
Ok so I've posted a video on the KZRiders FB page .....I hope that helps ......cheers guys
24 Jun 2016 10:37
I don't see it.
- Captainkiwi
- Vrooooooooom
24 Jun 2016 13:08
Checked cam tensioner check plugs all good there was no noise or rattle when I started it this morning but after checking everything you guys ahead suggested and I started the bike .......hello there is that annoying noise again so I'm looking around the bike and I notice that the kickstart is not quite fully returned so I pushed it back and hey presto noise gone......it's return spring is not working so I guess that when it's not seated fully back there is some gears just touching ....so glad it's nothing to serious .......so took it up the road for a blast in celebration
- Captainkiwi
- Vrooooooooom
24 Jun 2016 13:21 - 24 Jun 2016 13:25
This time ....still won't load video trying again
Last edit: 24 Jun 2016 13:25 by Captainkiwi.
- wrenchmonkey
24 Jun 2016 16:08
Well that's great news Cap'n!
Kudo's for sleuthing it out and glad it's nothing major (who actually uses their kick starters anymore anyway?).
Now you can install that coveted and rare Kick Starter Keeper Bungee Cord Accessory! :lol:
The following user(s) said Thank You: Captainkiwi
24 Jun 2016 16:14
The spring may not have been installed correctly or it's cracked. I'd check it out.
- Captainkiwi
- Vrooooooooom
24 Jun 2016 18:23
I was thinking I'd just remove it altogether ...lol.....on to the next job now fork seals and disk break caliper rebuild ......that should see me right for the summer
24 Jun 2016 18:33
Might just be a matter of giving the spring one more wind. I like having my kick starter. Had to use it a few times in the three years Bossie's been back on the road.
