No more Metal !
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
No more Metal !
23 Jun 2016 13:48
#732543
Just got back from another 70 mile ride on my 77' KZ1000A that I have brought back to life again. No problems on the ride. Now I have around 300 miles on the bike since being made operable again.
When I originally brought this bike home, I pulled the drain plug. With the Old Black oil that was in the bike, there were a lot of metal shavings as with a couple of larger metal pieces ? Suspected the worse but proceeded on with the project. Replaced the old oil with new and continued putting this bike back together . After I got bike was running it appeared to have starter clutch noise during start-up with the electric starter which resulted in the starter/clutch assembly and rotor being severely cracked and fragmented. So maybe these were the metal shaving I saw originally :whistle:
So after this latest ride, I decided to change the oil again and see if I had any metal shavings since I've been riding the bike for a while. Pulled the drain plug and examined the oil pan and am happy to report No Metal Shavings found :) :) Hopefully that was it.
Incidentally, I'm using Rosella T oil with the new oil change as recommended.
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • kzdcw
  • 77' KZ1000A
Re: No more Metal !
23 Jun 2016 14:26 - 23 Jun 2016 14:28
#732547
Thanks Steve :) :)
Next 2 things on the List :
1. Check if the fuel petcock is not totally shutting off fuel when turned off. Or check the float level Again ? Carbs. still puking out a little fuel out the float bowl overflow tubes when the bike sits for a few days even while on the center stand ? Maybe the float seats need to be changed out ?
2. Thought about checking the Head Torque valve? Maybe those low compression #'s I got earlier with the compression gauge could possibly be part of that ?
77' KZ1000A
Last edit: 23 Jun 2016 14:28 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: No more Metal !
23 Jun 2016 14:33
#732548
Look closely at the floats that the tangs aren't at too much an angle. That could make the needles cock to the side and not seal correctly.
  • kzdcw
  • 77' KZ1000A
Re: No more Metal !
23 Jun 2016 16:17 - 23 Jun 2016 16:18
#732555
Interesting, didn't think about that ? :whistle:
77' KZ1000A
Last edit: 23 Jun 2016 16:18 by kzdcw.
  • kzdcw
  • 77' KZ1000A
Re: No more Metal !
23 Jun 2016 20:04 - 23 Jun 2016 20:08
#732565
Steve, Do you think it is a good idea to check and re-torque the head bolts and nuts ? :cheer: Or is it better just leave it alone since it probably has never been checked since new and re-torquing it may cause more harm than good ?
Just grasping at straws since I had such a low compression test reading at all of the cylinder ? :huh: Even though I think this bike runs fairly decent with what I have to work with, I wonder how much better it would run if the compression #'s were above the service limit ? :whistle:
77' KZ1000A
Last edit: 23 Jun 2016 20:08 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: No more Metal !
23 Jun 2016 20:33
#732573
Fresh rebuild? Valves adjusted?
  • kzdcw
  • 77' KZ1000A
Re: No more Metal !
24 Jun 2016 04:10
#732589
Steve, This motor is Definitely not a fresh rebuild. Looking at it and the condition it was in when I first purchased it, ridden hard and put away after a lot of abuse. Don't even now if the 26,000 miles plus are even the right miles ?
So I'm assuming that re-torquing the heads in this old, aged motor would be a waste of time ?
Also, will look at the valve adjustment again. As it said earlier in Posts they did check out okay prior in clearance measurement but maybe something has changed ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: No more Metal !
24 Jun 2016 06:03
#732614
I wouldn't disturb the old gaskets.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: No more Metal !
24 Jun 2016 08:57
#732644
I check / retourque all my heads every few years, do it cold in several stages with a decent tourque wrench and according to the tightening sequence in the manual. Loose studs is a major cause of gasket failure imo.
