KZ1100 Valve cover gasket
- 76KZ900
21 Jun 2016 23:30
Ok so Im gonna try this again.. last time new rubbers and gasket still leaks. Looks like around left side front rubber location. I used black permatex last time and still leaked. Am I not holding my mouth right ? Anyone that has got this to seal feel free to share your magic...
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Re: KZ1100 Valve cover gasket
22 Jun 2016 05:45
I use the copper plus silicon. Be sure to put some on the top of the plugs too where the seams are. Grease on the gasket.
- SmokyOwl
22 Jun 2016 14:18 - 22 Jun 2016 14:47
I used black Permatex that's designed for oil leak prevention. Instead of leaving a "tube" of material around the holes I dabbed it on like a bingo dabber. Try leaving it to dry for MINIMUM 24 hours, I'd recommend 2 days. In my case I did have a leak at a plug after waiting 24 hours, but it went away the next day with no more leaks. Perhaps you might want to try a different gasket though, I've heard they are not all the same and some are worthless. Maybe the liquid gasket isn't bonding to the hard gasket well enough?
I ONLY put the black permatex on top of the rubber plugs, no where else. After it's applied I set down the gasket, then placed the valve cover on and torque to 87 inch pounds. And clean-clean-clean all surfaces prior to putting the gasket on.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
Last edit: 22 Jun 2016 14:47 by SmokyOwl.
22 Jun 2016 14:33
The copper is stickier than the other silicon.
- bountyhunter
22 Jun 2016 15:52 - 22 Jun 2016 15:59New rubbers have to be installed correctly to get set into the right place, it's a two step procedure. You run the black permatext around the rubber curved side of the rubbers and set the cover on without the gasket. Torque it down finger tight JUST ENOUGH to level off the top of the rubbers with the surface of the head and LET IT DRY FULLY (at least 24 hours). Then they will be set in place.76KZ900 wrote: Ok so Im gonna try this again.. last time new rubbers and gasket still leaks. Looks like around left side front rubber location
After that I still run a line of sealer across the rubbers to make sure they seal. The gasket should seal on the aluminum surfaces if they are clean and smooth.
Last edit: 22 Jun 2016 15:59 by bountyhunter.
- bountyhunter
22 Jun 2016 15:55 - 22 Jun 2016 15:56And there's a good reason why you need to there. The gasket over the rubbers pushes them down more compared to the aluminum surface so it puts a "corner" in the gasket at the edge of rubber to aluminum. Hard to explain, easy to see if you look at a used gasket. The areas of the gasket between two alum sides gets squeezed thinner than where it's over rubber.SmokyOwl wrote: I ONLY put the black permatex on top of the rubber plugs, no where else.
Last edit: 22 Jun 2016 15:56 by bountyhunter.
- 76KZ900
22 Jun 2016 21:17
I guess i did pretty much what was here with exception of letting it dry a long time.. I really cant remeber how long. I did put black permatex on rubbers and un the corners . Even on the bolts that go thru the rubbers .
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
