Please help 1978 Kawasaki kz650D sr
- Doliph650dsr
21 Jun 2016 09:08
I lost my book and need to do some matience I need to change oil but I don't know my torgue ft pounds for my oil filter bolt and drain plug and also for my spark plugs any help is appreciated thank you riders
- KZB2 650
Re: Please help 1978 Kawasaki kz650D sr
21 Jun 2016 09:30
From my factory 78 KZ650 B manual.
Oil filter bolt..... 13 to 16 foot lbs.
Drain plug......... 19.5 to 24 foot lbs.
Spark plugs ..... 18.5 to 22 foot lbs......... I till just lately always went by hand and have found out (by double checking with the wrench) that I went a good 15-20% less than the min on all 3 and they seemed plenty tight...... personally I will probably still go a little less on them but am not recommending this to others...... just sayin.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: Doliph650dsr
21 Jun 2016 09:38
I go by hand. On 30-40 year old bikes, the specs can no longer apply. Just remember, righty-tighty, lefty-loosey. Use a 6 point socket that fits tight and if it won't come off, find out why.
- davido
21 Jun 2016 11:10
I agree with Steve,just do it by hand. Both the plugs and the drain bolt have sealing washers on them,so as long as you tighten them down,enough to crush the washers a bit, you should be Ok.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
21 Jun 2016 11:24
Spark plug threads are easy to cross thread. Be careful. If they won't go in easy, back them out and start again until they do.
