POSITIVE UPDATE: Painfull Lessons of Camshaft
- keconomos@sbcglobal.net
21 Jun 2016 07:42 - 21 Jun 2016 07:44
After trying very hard to wreck the top end on the engine of my KZ1000P-24 20005 Police bike by stripping 7 camshaft tower bolts out the head, installing time serts, breaking camshaft tower two, putting it back together and hearing some nasty noises from the camshaft area near tower 4 - I am happy to report that I went on a great ride this past Saturday - the bike ran better than ever.
During the process, after having installed the time serts and relacing the broken cam tower two, I put her back together and started her up- she ran fine but I listening around - there was some nasty noise coming from around tower 4. I figured for sure that it was a misaligned camshaft from all the hacking around I did on the bolt holes. I assumed the worst and pictured taking the whole thing apart and having to replace the head.
However when I opened her up- the cams were fine no muss no fuss. I concluded that the noise came from reinstalling the reed valves in the cover head with gaskets that were busted in a few places - filling the broken areas in with gasket compound- dumb but I didn't want to wait for new gaskets. Air must have been sucking through there, rumbling and vibrating. I replaced the gaskets and when it was back together - no noise.
I adjusted air/fuel, synched the carbs and the bike is running very well.
A happy ending (at least for the time being) to a sordid and epic tale.
Last edit: 21 Jun 2016 07:44 by keconomos@sbcglobal.net. Reason: type
- Tyrell Corp
Re: POSITIVE UPDATE: Painfull Lessons of Camshaft
21 Jun 2016 08:17 - 21 Jun 2016 08:19
Sometimes great things don't work out first time around, I dropped some major clangers too in the early days.
Careful with using car rated tourque wrenches on the M6 cam bolts, they are bastards for stripping - or even worse breaking off inside the head, just when you are buttoning the job up.
I do it by hand with threadlock and replace bolts for new high tensile steel...the bolts can stretch over time and repeated dissasembly.
Last edit: 21 Jun 2016 08:19 by Tyrell Corp.
21 Jun 2016 08:38 - 21 Jun 2016 08:39
Thanks for the reply, I had never worked on an aluminum engine before- boy this has been a "quick to screw-up" and steep learning curve for me but I have learned a ton. And yes- spring for new bolts, stretched threads on steel bolts will tear out the threads on bolt holes in an aluminum head.
Last edit: 21 Jun 2016 08:39 by keconomos@sbcglobal.net. Reason: typo
- wrenchmonkey
21 Jun 2016 16:39
Kudos on the success!
I'm sure there were some pretty blue words yelling out of the garage during the process but that last ride musta' made them all a distant (but learned from) memory.
So where's the pics darn it? :laugh:
21 Jun 2016 17:18 - 21 Jun 2016 17:55
Thanks,
PICS Coming
PICS Coming
Last edit: 21 Jun 2016 17:55 by keconomos@sbcglobal.net. Reason: typo
