Valve Shim Tools ?
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: Valve Shim Tools ?
13 Jun 2016 19:25
#731286
Ah yes just like the 550. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Jun 2016 19:30
#731287
At least they won't get spit out with hot cams. :lol:
  • kaw-a-holic
  • kaw-a-holic's Avatar
13 Jun 2016 21:30
#731302
rrsmsw9999 wrote: zip tie in the spark plug hole to the valve open is hands down easy. The valves are easy to see open and the tie bent over is plenty strong enough and will not mar the valve seat. Turn the crank to get to each shim. Open valve, place ziptie, rotate carnk a hair to create space between the cam lobe and shim and remove shim. Had three shims out and miced in 10 minutes. Very easy, no backing up the cam lobe, nothing to damage. R
After reading glasses this is had to go try it. THANK YOU! That is the fastest I have ever re-shimmer the motor ever.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
14 Jun 2016 20:43
#731425
Does it matter what size zip ties that you use ? I have 2 different sized zip ties on hand. One is 11" long a little more than 1/8" wide. The other is 13" long and a little more than 1/4" wide.
Do they have to be folded over or just side the end on the zip tie under the valve and seat? The shorter zip tie I have is thinner so it would be more flexible but would it be thick enough to hold the valve open enough to remove the shim?
77' KZ1000A
  • kaw-a-holic
14 Jun 2016 20:53 - 15 Jun 2016 05:33
#731428
kzdcw wrote: Does it matter what size zip ties that you use ? I have 2 different sized zip ties on hand. One is 11" long a little more than 1/8" wide. The other is 13" long and a little more than 1/4" wide.
I used an 11"X1/4. I folded it in half and then folded the end again. To make things easier I heated it up with a lighter and pressed it in my vice. Worked great. The more you can get the valve to stay open the easier it is remove the shim.
Jon
1977 KZ1000a1
Mesa, AZ
Last edit: 15 Jun 2016 05:33 by kaw-a-holic.
  • rrsmsw9999
14 Jun 2016 21:03
#731431
You can see a short video on my 1980 ST project thread. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • kzdcw
  • 77' KZ1000A
15 Jun 2016 00:36
#731443
Jon, I think you answered my Post with the 11" long zip tie that I have on hand ?
Saw the Video and looks like the same zip tie I have ( 11" )? Not sure where you make the Fold on the zip tie but should be able to figure it out?
77' KZ1000A
