Is this newly purchased head gasket damaged?
- aenikolopov
09 Jun 2016 13:20 - 09 Jun 2016 14:11
Hi all. I'm doing a top end job on my 1980 kz650, and I ordered a kawi manufactured NOS head gasket from ebay. I received it and ther are several issues I'm not sure about. I was wondering if these problems are serious ones, especially #1. Should I order a new gasket, or are these not really problems.
#1 - The edge of one of the ends of the aluminum headgasket is bent. I think this must have happened during shipping.
(zoom of above)
#2 - The gasket is made of two sandwiched pieces of aluminum. These are not fully bound together, they are delaminated. Are they supposed to be?
#3) There is very fine rubber covering, like a paint, on portions of the gasket, and it has begun to flake/pull/rub off.
Attachment headgasket1.jpg not found
(zoom of above)
Attachment headgasket1zoom.jpg not found
Attachment headgasket2.jpg not found
Attachment headgasket3.jpg not found
Last edit: 09 Jun 2016 14:11 by aenikolopov.
- Mcdroid
- Gone Kwackers
Re: Is this newly purchased head gasket damaged?
09 Jun 2016 14:22
Get your money back...if possible.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
09 Jun 2016 14:28
Not as described.
09 Jun 2016 15:20
Send it back and buy a genuine Kawasaki head gasket from a different source. To me that one does not look like one made by Kawasaki. Ed
09 Jun 2016 15:22
NOS is often old junk. Try to find a Cometic.
- aenikolopov
09 Jun 2016 15:41Thanks all for your thoughts. I'll find a replacement. Steve, I thought I had heard someone on this site write that I should try to find a kawi-manufactured replacement. You've had good luck w/ the Cometics?swest wrote: NOS is often old junk. Try to find a Cometic.
- razmo99
09 Jun 2016 15:42
If you have the Kawasaki part number, for that head gasket, email your local Kawasaki dealer and see if they have it, I have had good luck finding new parts for old bikes, and the best part of it is they are always in good condition.
- Z500 B4
-GPZ900R A9-10 ish
-GPZ900R A9-10 ish
09 Jun 2016 15:47
That would be best. I've always had good luck with Cometic's.
- aenikolopov
09 Jun 2016 15:54swest wrote: That would be best. I've always had good luck with Cometic's.
OK, i'll give them a go. I was put off originally because the Kawi part is aluminum is Cometic only makes a fiber gasket for this bike.
09 Jun 2016 16:01
I have a one piece fiber head gasket on my Z1. No leaks.
The following user(s) said Thank You: aenikolopov
09 Jun 2016 16:18
I'll take an OEM Kawasaki gasket over aftermarket anyday.
- Tyrell Corp
11 Jun 2016 17:24
I think you will find it is a 3 piece, the later model laminte gasket with the coating. Looks like it got damaged in the post, or got left on a shelf for 30 years for a reason....
It will bend back, if it is unused I think. The main issue is whether it has been fitted and the bore pressings are crushed.
Torque your head down in stages, and retourque when cold after a few hundred miles or so.
