GPz struggles at 3000+ rpm
- mangosteen
02 Jun 2016 18:42
Hey all,
My 83 GPz 550 recently had a carb cleaning and oil change. Lately, its been struggling, on and off, at anything higher than 3000 or 3500 rpms. After pulling the carbs and giving them another look over (still clean), I can't figure out what's going on.
The problem is constant now. Here are some clues; maybe someone can lend some advice.
-In neutral, the bike will rev up to 6000 rpms, if I SLOWLY twist the throttle. If I rev it QUICKLY, it sounds starved for gas, and putters until I release the throttle
-In first, second, and third gear, it'll smoothly climb up to right around 3000 rpms, and top out. I haven't been able to get up to speed to see whats going on in the higher gears.
-This bike came with pod filters, and ran well for about a year, so I'm thinking it was (hopefully) properly re-jetted. The PO had installed a pre filter in the fuel line. I've temporarily removed it and routed it stock-style, petcock to carb, to make sure there was no funny business happening in the tank-to-carb route.
-Maybe irrelevant, but I put a new clutch cable in recently. Smooth as can be, and shifts perfectly. Just noting it because things started getting funny after the last round of work (clutch cable, fork seals, carb cleaning, etc.)
I have two theories, but I'm probably way off base: There's been a minor off-and-on smear of oil on the left side cylinder head. Could a head gasket be causing these symptoms? My other thought is that maybe it's just a mixture issue? Are these pod filters in need of replacement or cleaning?
Anyway, thanks for reading and responding, Any help is always appreciated.
Always trying to ride more than wrench... someday.
Thanks,
Joe
Thanks,
Joe
1983 GPz 550
Re: GPz struggles at 3000+ rpm
02 Jun 2016 18:48
Pic of the bike? What kind of carbs? Checked the spark advance to see if it moves freely?
02 Jun 2016 18:50
And have you adjusted the valves?
- Nebr_Rex
02 Jun 2016 19:01
Reinstall that inline filter and clean your carbs again.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- mangosteen
03 Jun 2016 05:13swest wrote: And have you adjusted the valves?
I haven't adjusted the valves. I suppose they're due for a check. I believe the carbs are the TK 26's. I'll double check today.
Thanks
1983 GPz 550
- loudhvx
03 Jun 2016 06:28
As steve mentioned, Spark advanced would be the first thing I'd check. It may have seized up during maintenance down time.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- shamal
06 Jun 2016 10:39
or maybe a little hole in one or more carb diaphragms..
i had something similar in the past. in neutral the bike run well, not the same under load .
1983 kz 550 h
- mangosteen
12 Jun 2016 10:02
Thanks, everyone. Pulled the plugs and did a compression test and everything was fine. Pulled the carbs AGAIN and actually managed to get out the smallest jet (not sure which it is, but the one hiding under the plastic plug.)
The last time I had them off, everything looked pretty good, so I assumed the smallest jet was also fine. Also didn't have a small enough flat head to get to it. I had to grind an allen key flat on one end for a make shift flat head. Turns out they were pretty dirty.
I reckon the PO also got in there, realized he didn't have a small enough screwdriver, and left that one for the next sucker.
Anyway, thanks for the input. Bike is running better than ever now.
Next up: swapping out the clutch lever that I sheared off opening the garage door carelessly.
Oh, joy.
Oh, joy.
1983 GPz 550
- shamal
