Front motor mount + case savers = problems
- nitrokeeb
02 Jun 2016 10:28
The long bolt that goes through the case and both front motor mounts is to short to accommodate the case savers. I know I can get an all thread rod, but have seen others comment that its weaker and will sag. Is their any reason I can't use one bolt per side? Maybe an Allan bolt so the head can easily fit in the gap at the front of the engine.
1978 KZ1000B LTD w/KZ900 engine
- zed1015
Re: Front motor mount + case savers = problems
02 Jun 2016 11:34
The reason not to use threaded bar is that the threads chew in to the alloy cases and where they go through the frame.
Nothing to do with sag.
Best to get some plain 10mm bar and have it threaded both ends for nylocks or have some hex bar turned into a proper bolt.
The long bolt makes for a more rigid structure than trying to use a short bolt either side for which there is not enough meat to support an allen head in the inside of the case.
You may be able to fit one off elongated nuts (similar to the bottom mounts pear shaped captive nut ) either side which slots in to the casing but as mentioned you will lose some rigidity.
The following user(s) said Thank You: Patton
- Barry2
02 Jun 2016 12:23
Check with one of the bolt stores such as Fasteners, or fastenall or whatever they are named in your area.
1976 KZ900
- nitrokeeb
02 Jun 2016 20:18
Well the hardware store didn't have long enough Allan bolts in 10mm or 3/8th, so I came home with allthread (in stainless no less). I wasn't satisfied as I'm trying to undue all half-assedness done to this bike over nearly 40 years. I looked at fastenal's website and the longest bolt they offer is just over 10 inches. And turning hex stock down is great in theory, but I no longer have access to a lathe. But I think I could cut threads on a rod. My wife works for a steel company, so I asked her if they carried 10mm bar. Probably not, she said, but that's close to 3/8. So a quick Google search led me to eBay, and now I have a 20 inch long stainless rod on route by way of the next boat from China.
- toolmaker
03 Jun 2016 06:00
You do know that stainless is probably not as strong as standard steel, don''t you? Be careful not to strip the threads....
I live near Portland, Oregon and my rider is a '76 KZ900 I bought new. I'm also in the process of restoring another one and a '73 Z1.
