82 GPZ 1100 Clutch Issues
- pjluckai
31 May 2016 20:53
Hey guys, long time onlooker, first time poster.
After about a year of looking, I finally found an 82 GPZ 1100 in good condition with a reasonable price tag. So I drove 700km and picked her up. During the first ride I noticed significant clutch slippage (next to no power on revs). The previous owner had proclaimed that he had just had the clutch shimmed, but evidently that is not the case.
So, I took the clutch apart and checked plate thickness; all bang on spec. I went ahead with the degreaser and scotch brite trick to see if residue buildup, etc on the plates was the issue. Topped up with Kawasaki S4 synthetic, and a filter I took it for a spin..... no improvement. Fiddled with the clutch lever adjustment, and nothing either. Are there any other adjustments I'm missing? Owner's manual is in the mail....
Any suggestions for next steps? I'm assuming springs are next on the list....
Thanks
Thanks
Pete
'82 GPZ 1100
'82 GPZ 1100
Re: 82 GPZ 1100 Clutch Issues
31 May 2016 22:45
Yup, springs.
- mjg15
01 Jun 2016 02:07
Push rod mechanism adjusted as per manual?
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Bozo
- Ride it like u stole it
01 Jun 2016 03:00 - 01 Jun 2016 03:01
Check if the clutch plates are correctly fitted, the outside fibre plate might be in the wrong slot (not 100% sure this can be done). The previous owner might not have fitted it correctly and obviously there is some adjustment in the lever.
Do not ride with the slip
Last edit: 01 Jun 2016 03:01 by Bozo. Reason: adding content
- pjluckai
01 Jun 2016 05:25 - 01 Jun 2016 05:30
No, but thanks for the pushrod tip I'll try that tonight.
Pete
'82 GPZ 1100
'82 GPZ 1100
Last edit: 01 Jun 2016 05:30 by pjluckai.
01 Jun 2016 05:27
Clutch shimmed, weak springs.
- pjluckai
01 Jun 2016 05:32The final friction plate has a certain orientation?Check if the clutch plates are correctly fitted, the outside fibre plate might be in the wrong slot (not 100% sure this can be done). The previous owner might not have fitted it correctly and obviously there is some adjustment in the lever.
Pete
'82 GPZ 1100
'82 GPZ 1100
01 Jun 2016 06:11Be sure there are no notches in the aluminum hub. The last one is a friction plate. The outside pressure plate shouldn't have a ridge on it or cracks.
- mjg15
01 Jun 2016 09:09pjluckai wrote: No, but thanks for the pushrod tip I'll try that tonight.
Follow procedure in manual.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- pjluckai
01 Jun 2016 21:17mjg15 wrote:pjluckai wrote: No, but thanks for the pushrod tip I'll try that tonight.
Success! such an easy fix... previous owner had the pushrod adjusted the wrong direction. Oh well, runs like a charm, thanks!
Pete
'82 GPZ 1100
'82 GPZ 1100
- Bozo
02 Jun 2016 01:53
Great news just hope you didn't glaze the plates, enjoy
- mjg15
02 Jun 2016 16:08 - 02 Jun 2016 16:10pjluckai wrote:mjg15 wrote:pjluckai wrote: No, but thanks for the pushrod tip I'll try that tonight.
Pretty common malady here, and always a good thing to check first. Glad it was an easy fix!
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 02 Jun 2016 16:10 by mjg15.
