Oil Pressure Gauge ???
- kzdcw
- 77' KZ1000A
27 May 2016 17:05
Like to replace the oil pressure gauge that is currently mounted at the oil port on the right side of the motor on my 77' KZ1000A.
Gauge is a 2 1/4" O.D. 80 lb. reading with a 3/8" NPT male end.
Is there a recommended gauge preferably white face with this size male end that would screw into the 90 degree elbow already on the bike?
77' KZ1000A
Re: Oil Pressure Gauge ???
27 May 2016 17:17
Lots on eBay. I got a Doremi gauge but blew it out. They sent me another one, it did the same thing. I kept the fittings and got a 60 PSI gauge for a sportster. My oil pressure is very high.
27 May 2016 17:21
Now that I have the cooler installed. I'm going to put in a tap and hook up the gauge in my dash.
27 May 2016 18:09
Since Kz 1000s run about 3 psi when hot I have a 15psi gauge on my bike. Its work perfectly since 1980
When motor is cold the gauge reads to 15 or a little more ,
but as the motor comes up to temp the psi drops to a steady 3 or so above idle speed
- kzdcw
- 77' KZ1000A
27 May 2016 18:22
What manufacture and size of gauge are you guys using ? I'm assuming this is a Mechanical Gauge ? Do I look for a gauge that measures 3/8" O.D. at the male end threads that screw into the adapter ?
77' KZ1000A
27 May 2016 18:29
- kzdcw
- 77' KZ1000A
27 May 2016 18:43
Steve, Identical to your Picture I have on my Bike. I measured Both threaded male ends at both the gauge and at the male threaded in that screws into the motor, it appears they measure 3/8".
My gauge registers 0-80 lbs., so I would like find a gauge like above that registers around 15 lbs.
77' KZ1000A
27 May 2016 19:28 - 27 May 2016 19:29
The doremi gauges should work for you. I modified my oil pump so my pressure is too much for them to handle. Ebay
steve
steve
Last edit: 27 May 2016 19:29 by SWest. Reason: sp damn lap top
- kzdcw
- 77' KZ1000A
28 May 2016 00:07
Steve, What diameter is your gauge ? I'm only finding 1 1/2" diameter with 1/8 NPT center back fitting ?
77' KZ1000A
28 May 2016 05:15
That's what they are. Why would you want a larger one? I had to take the bezel off in order to put the larger gauge on and it looked like crap.
- pete greek1
28 May 2016 09:56
Pete
kzdcw wrote: Steve, Identical to your Picture I have on my Bike. I measured Both threaded male ends at both the gauge and at the male threaded in that screws into the motor, it appears they measure 3/8".
Pete
28 May 2016 15:18
That would be the right gauge in white or black face as listed
pete greek1 wrote:kzdcw wrote: Steve, Identical to your Picture I have on my Bike. I measured Both threaded male ends at both the gauge and at the male threaded in that screws into the motor, it appears they measure 3/8".
Pete
