KZ1000 Flywheel won't come off!
  • pinkiedog64
  • pinkiedog64's Avatar Topic Author
23 May 2016 20:21
#728169
Hello all,
Trying to remove flywheel from 1980 KZ1000E shaft drive to replace starter overrun clutch pieces. Took much effort to remove flywheel bolt...way more than I thought it should. Had to use impact and heat. Once I got it off I saw remnants of red Loctite on the bolt and not just a tiny dab; the whole bolt was covered. Have correct puller bolt (M16x1.5 I believe). Threads in fine and bottoms out against end of crank like it should. Have tried tightening the heck out of it and wracking end of puller bolt and also applying heat from propane torch. Still not coming off. Have even tried impact on puller bolt to no avail. I'm thinking some previous owner put red Loctite on the taper fit of the flywheel-to-crank and I just haven't been able to overcome it. Any ideas?
Thanks,
Stephan
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ1000 Flywheel won't come off!
23 May 2016 20:24
#728170
Keep heating it. Apply the heat inside the rotor then try the puller.
  • pinkiedog64
23 May 2016 20:44
#728173
Will try. Is there a seal where the crank goes through the case that may be get damaged or melt? I believe red loctite gives way at or above 350F. Should I be worried about heat transferring into other parts like deals or flywheel magnets?
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2016 20:57
#728174
That's why I was suggesting heat in the center. The aluminum and magnets should act as a heat sync. Try to heat the inside of the hub not the crank. Good luck.
  • PLUMMEN
  • PLUMMEN's Avatar
23 May 2016 22:51
#728185
Get the biggest ball bearing you can fit in the bolt hole before running the bolt in. ;)
  • etbike3135
  • etbike3135's Avatar
24 May 2016 03:59
#728193
Careful with the heat if you want to reuse the rotor. If you get too close to the magnets they will break and come off, rotor will be shot.
Sometimes thats all you can do. Some rotors are just on there that tight. I doubt red lock tite would hole that on there like that, they make grey locktite for press fits but I wouldn't use it.
1973 Kawasaki Z1
18 years in dragbikes
  • djturnz
  • djturnz's Avatar
29 Jun 2016 16:29
#733306
Some years of rear axle will thread in. I did that with a weight on it and made like a slide hammer.
1982 KZ750 (4) LTD
