What did I do wrong?
- Yetanotherkzrider
22 May 2016 15:12
I installed my cams earlier, according to the instructions that are everywhere. Now I can't turn the engine over completely. It almost cycles and then makes a tink noise. Did I bend a valve somehow? I'm at a loss.
Re: What did I do wrong?
22 May 2016 15:20
You must have set it wrong. Don't force it. Recheck the timing.
The following user(s) said Thank You: Yetanotherkzrider
- Yetanotherkzrider
22 May 2016 15:34
Is it possible for the cam chain to bind on the crank? I took the cams back out and it cycled fine until I messed with the chain a little.
- zed1015
22 May 2016 15:41
Yes ! it's possible for the chain to bunch on the crank by a couple of links .
Also possible for the chain miss the crank sprocket and run at the side of it.
Both situations will cause the timing to slip or the crank to lock.
- Yetanotherkzrider
22 May 2016 15:52
Cams are out again and I found what I believe to be the culprit, a massive chunk of zip tie in the cam chain channel, which also caused the chain to bunch up on the crank. I fished it out of there and decided to take a break. Another question for anyone who might know. When I align the arrow on the exhaust cam up with the surface of the head, it falls back a fraction of a link no matter what I do, unless i hild it there. Normal?
zed1015 wrote: Yes ! it's possible for the chain to bunch on the crank by a couple of links .
- zed1015
22 May 2016 16:15
If you are talking of valve spring pressure rotating the cam a little then yes! that is normal.
Also when fully assembled, the timing mark hardly ever lines up exactly with the head surface due to factory tolerances, deck height, cam chain wear etc.
It's usually a mill or two above or below,
As long as it's not obviously a tooth out when it's all assembled it will be ok.
- Yetanotherkzrider
22 May 2016 16:25
that's exactly what I meant. I'm going to have some coffee and get back to it. Thanks.
- daveo
22 May 2016 17:26 - 22 May 2016 17:29
Use extra care installing the cam caps and bolts.
View post #693290
www.kzrider.com/forum/2-engine/599907-kz...ve-adjustment#693290
View post #693290
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 22 May 2016 17:29 by daveo. Reason: easy link
- Yetanotherkzrider
22 May 2016 17:40 - 22 May 2016 17:51
Good news! Cams are in and it cycles freely! But after cycling it a few times the lobes no longer match up perfectly on tdc. Am I being pedantic? Or I this due to the fact that I haven't adjusted the tensioner yet?
Last edit: 22 May 2016 17:51 by Yetanotherkzrider.
22 May 2016 18:07
That's wrong. The arrow should be even or below the head. Count starting with the next pin to 28. Put the tentioner on before turning the engine.
- Yetanotherkzrider
22 May 2016 18:14
Damn. I thought that looked even. So it needs to go down more? And the only tensioner I have is the manual APE brand, so how should I go about that?
22 May 2016 18:23
Might be the angle. The arrow is on a even pin but the 28 is on a odd one. Should be right. What condition are the rollers in?
