1980 kz750 oil pressure light coming on when hot
  • brokenspoke
  • brokenspoke's Avatar Topic Author
20 May 2016 17:35
#727658
Has anyone had any issues with the oil warning light coming on when their bike is hot? Running around home here it doesn't come on but the other day I ran it about 25 miles and got stuck in traffic and it would come on at idle (about 1400 rpm) it would usually go off at about 1800-2000 rpm. Stopped for about 1/2 hour started it up and it was good again until I was again in slow traffic. Once I got out of town and got some speed(cooling) it would "flicker" at idle. Running Rotella 15w40 oil, fresh change with a new oil filter and I didn't notice anything in the oil at the last oil change (Monday evening, 150ish miles ago). I did think the bike ran hot but can't see how to improve the cooling any other than by adding a oil cooler. Could be running a little lean causing some additional heat but with fresh carbs and everything at stock settings I don't think that is the issue. Unfortunately I have no history on the bike so I don't know if this was an issue before. Thanks.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1980 kz750 oil pressure light coming on when hot
20 May 2016 17:49
#727659
You should get a gauge and check the pressure.
  • brokenspoke
21 May 2016 05:54
#727727
UnfortunatelyI don't have the fitting to attach my gauge to the test port. Is there another place I can tap into the oil pressure system?
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2016 05:57
#727728
You will need a fitting no matter where you test it.
